I am using deepstream app with a customized dsexample plugin. The issue is when I try to access the boxes in dsexample plugin, the boxes jump between sources.
Could you give more details about " the boxes jump between sources."?
This behaviour is quite random. I am using 2rtsp sources and sometimes boxes from one come on the other’s output.
We didn’t observe the issue, pls help to provide more details if you need help.
