I am trying to use some of the code from boxfilter example to perform filtering on an image that is stored a buffer allocated by mallocmanaged.
Code to allocate buffer:
cudaMallocManaged(&buffer, width * height * 3 * sizeof(float));
Code to initialize texture:
void initTexture(int width, int height, void *pImage)
int size = width * height * sizeof(float);
// copy image data to array
cudaChannelFormatDesc channelDesc;
channelDesc = cudaCreateChannelDesc(32, 0, 0, 0, cudaChannelFormatKindFloat);
cudaMallocArray(&d_array, &channelDesc, width, height);
cudaMemcpyToArray(d_array, 0, 0, pImage, size, cudaMemcpyDeviceToDevice);
cudaMallocArray(&d_tempArray, &channelDesc, width, height);
// set texture parameters
tex.addressMode[0] = cudaAddressModeClamp;
tex.addressMode[1] = cudaAddressModeClamp;
tex.filterMode = cudaFilterModeLinear;
tex.normalized = false;
// Bind the array to the texture
cudaBindTextureToArray(tex, d_array, channelDesc);
Code to run filter in x:
__global__ void
d_boxfilter_x_tex(float *od, int w, int h, int r)
float scale = 1.0f / (float)((r << 1) + 1);
unsigned int y = blockIdx.x*blockDim.x + threadIdx.x;
float t = 0.0f;
for (int x =- r; x <= r; x++)
t += tex2D(tex, x, y);
printf("%X\n", t);
od[y * w] = t * scale;
for (int x = 1; x < w; x++)
t += tex2D(tex, x + r, y);
t -= tex2D(tex, x - r - 1, y);
od[y * w + x] = t * scale;
When running it like this my image is really dark with red colors highlighting the textures within the image. If run as follows, the image is in proper color:
__device__ void
d_boxfilter_x(float *id, float *od, int w, int h, int r)
float t;
// do left edge
t = id[0] * r;
for (int x = 0; x < (r + 1); x++)
t += id[x];
od[0] = t * scale;
for (int x = 1; x < (r + 1); x++)
t += id[x + r];
t -= id[0];
od[x] = t * scale;
// main loop
for (int x = (r + 1); x < w - r; x++)
t += id[x + r];
t -= id[x - r - 1];
od[x] = t * scale;
// do right edge
for (int x = w - r; x < w; x++)
t += id[w - 1];
t -= id[x - r - 1];
od[x] = t * scale;
I think it is the way the mallocmanaged buffer is being mapped to the texture memory but not sure. Anyone know what could be going on?
