Hello, I don’t understand the configuration item of uart1 in “Device tree for both kernel and bootloader” in this post. Could you please explain what these four hexadecimal numbers represent? Thank you!
May I know what’s your use case for this?
Are you also trying to redirect the debug output to uarta(serial@3100000)?
They are the configuration in BPMP-DTB. 0x9b is the instance for uarta interface. 0x66 is the the parent clock in use. 0x1c1b40 is the baudrate mutiply by 16 0x8 is the ID for Door Bell
About “0x1c1b40 is baud rate multiplied by 16”, why is 0x1c1b40 divided by 16 115124 instead of 115200? I don’t understand the specific meaning of “0x8 is the ID for Door Bell”. Is there any documentation on these nouns?
Actually, we don’t want customer to modify the content in BPMP-DTB and there’s no public document for them.
I could instruct you with the approach for your use case but it’s hard to explain all logic inside.
