BPMP "start PLL 8 calibration failed" on custom carrier: same module+image boots on devkit, fails on carrier without UPHY refclk
I’m upgrading Orin jetpack from L4T r35.4.1 to r36.5.0 and have isolated what looks like a BPMP-FW behavior change between the releases. We run on a custom carrier board with no 156.25 MHz clock. We have it running on r35.4.1, but it won’t boot on r36.5.0.
Hardware
  • Module: AGX Orin 64GB, P3701-0005
  • Custom carrier: no MGBE, EQOS/RGMII only. The module’s UPHY_REFCLK1/2 input pins are not connected; no 156.25 MHz clock.
  • PCIe: C7 x8 (GBE brick lanes) to an M.2 NVMe slot, C5 x8 (NVHS) to an FPGA — both Root Port, Orin supplying the 100 MHz refclk out to the endpoints.
The problem
Same carrier, same module, same ODMDATA and device-tree UPHY assignments: boots and runs fine on r35.4.1 (NVMe on the GBE lanes fully functional). On r36.5.0, every boot dies in BPMP-FW:
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
start PLL 8 calibration timeout
FATAL ERROR [FILE=platform/drivers/uphy/uphy-tegra234.c, ERR_UID=2251]: start PLL 8 calibration failed
then UEFI hangs at HspDoorbellEnableChannel: Waiting for HSP Doorbell Channel Enabled.
What I tried
  1. gbe-uphy-config has no effect. I tested 22, 1, and 0 — each verified deployed (MB1 logs W> Skipping GBE UPHY config for the non-MGBE values) — and all three crash identically, from both boot chains (Slot 0 and Slot 1 captures). On r35.x, gbe-uphy-config-0 was the accepted fix for carriers without the MGBE clock (e.g. topic 366345); on r36.5.0 it does not appear to prevent the PLL 8 calibration attempt.
  2. The same module boots r36.5.0 fine on the devkit carrier, on both the non-MGBE config and the stock config (gbe-uphy-config-22 + gbe0-enable-10g). At the exact point where the custom carrier dies, the devkit’s BPMP log goes HSIO UPHY reset has been de-asserted then initialized uphy with no PLL 8 message.
  3. Nothing in our config surface changed between releases. The BPMP-FW DTB /uphy node and default ODMDATA are byte-identical.
Questions
On r36.x, BPMP-FW seems to calibrate PLL 8 (GBE brick) unconditionally at init, requiring a reference clock that’s missing.
  1. Is there a supported ODMDATA / BCT / BPMP-FW-DTB setting in r36.x that prevents the fatal PLL 8 calibration on carriers with unconnected UPHY_REFCLK inputs?
  2. If not, is PCIe-over-GBE-lanes (C7 RP) still supported on r36.x without the 156.25 MHz clock?
  3. If the carrier must provide the refclk on r36.x with no alternatives, please let me know so we can plan a board revision.
Logs attached: r36.5.0 failing boot (custom carrier), r36.5.0 successful boot (same module, devkit).
screenlog_devkit_36.5.txt (212.0 KB)
screenlog_carrier_36.5.txt (55.5 KB)
Hi cat.culkin,
Have you tries using the BPMP-FW and DTB from r35.4.1 for the r36.5.0 to check if it could unblock the current issue?
Do you mean the issue is specific to your custom carrier board?
If so, have you referred to Jetson AGX Orin Platform Adaptation and Bring-Up — NVIDIA Jetson Linux Developer Guide to port r36.5 for the custom carrier board?
There is no new issue here. I feel you just didn’t configure the ODMDATA correctly.
gbe-uphy-config-0 is still the correct ODMDATA if you don’t have MGBE Refclk.
Do you remember to remove gbe0-enable-10g?
Have you disabled the MGBE node in kernel DT?
