Breaking Change During Azure Installation - Installation Container - AODT 1.1
Version 2.64.0 of the Azure CLI container (mcr.microsoft.com/azure-cli) was released on September 3, 2024 and has a breaking change that affects AODT installation scripts for Azure. See the release notes here: Release notes & updates – Azure CLI | Microsoft Learn. The specific change that affects the AODT installation in Azure is the use of CBL-Mariner as the base OS rather than Alpine. Because of this, the azure_install.sh script will fail. The documentation has been updated with the docker run command to explicitly call out the previous tagged version of 2.63.0. Please use the following docker run command when starting up the azure-cli container during an installation for AODT 1.1 (i.e. explicitly choose the 2.63.0 tag)
docker run -it --env-file .secrets -v .:/aodt -v ~/.ssh/azure.pem:/root/.ssh/id_rsa mcr.microsoft.com/azure-cli:2.63.0.
