Breakpoint is skipped in emulation mode
Hi all,
I have a problem Debugging in emulation mode. When I set breakpoint inside the kernel file, compiler simply skips the breakpoint with the notification “Break point will not currently be hit. Cannot set breakpoint at line…”. I’m using PVF 15.3 with the VS2010 (Win 8.1). Can you please help.
Thanks in advance
Did you compile with -g?
brentl,
Sorry for late reaction to your post. Yes, I have compiled using -g option. I try everything, but persistently I get the same message “The breakpoint will not currently be hit. Cannot set breakpoint at line……”. However, outside of the kernel the debugger run perfectly. Do you have any ideas.
Thank you in advance.
