I am trying to debug a proof-of-concept small C++ app. The app consists from one cpp file (main.cpp) which calls a wrapper function defined in a *.cu file. This wrapper function then calls another function defined in this *.cu file, which is decorated with _host_ _device_ attributes.
The *.cpp file is compiled with gcc, the *.cu file is compiled with nvcc. Linking and building is done with nvcc. Compiling and linking is using flags g and G also.
When I debug the app with cuda-gdb, I can hit breakpoints in the functions from *.cu file, but the breakpoints in the main.cpp are skipped.
In the debug console is a message: No source file named /.. full path…/main.cpp
After that it outputs the breakpoint in the wrapper function from the *.cu file, in which the debugger hits the breakpoint as expected.
If I debug using gcc, there is no message “No source file named / full path…/main.cpp” in the debug console, and all breakpoints are listed with lines numbers, but no breakpoint from *.cpp file will be hit. The breakpoints in *.cu files are working as expected.
When looking for answers I came across cases when the g, G flags helped. However, I am using these flags, so this is not a problem.
Am I missing some different flags?
I am using Cuda Toolkit 13, Ubuntu 24, std:C++20, VS Code.
Thanks for help.
