I’ll be using Brev for a digital twin project on a modular production line, since my local hardware (Quadro RTX 3000, 6 GB VRAM) is below the Isaac Sim minimum. The official Brev deployment guide recommends an L40S GPU. For a mid-complexity scene (~5 workstations, machines, factory floor, physics simulation for throughput and bottleneck analysis), is the L40S the right pick, or would an A10 be enough?
The L40S is the right choice for your use case. A scene with 5 workstations, physics simulation, and bottleneck analysis is exactly where the A10’s 24 GB VRAM starts to become a limiting factor — the L40S gives you the headroom to work without constantly running up against hardware constraints. That means less time troubleshooting performance and more time actually building your digital twin.
Thank you for the recommendation. I found this L40S configuration on
Brev:
AWS g6e.2xlarge
1x L40S (44.7 GiB VRAM)
8 CPUs / 64 GiB RAM
$2.69/hr + $0.04/hr storage
Stop/start enabled
Does this look right for an internship workflow where I need stop/start,
saved progress between sessions, and the full Isaac Sim 5.1 experience
like running it locally?
Also, are there any student or internship discounts available?
Yes, that configuration looks right for this workflow. The AWS g6e.2xlarge shape gives you 1x L40S, 8 vCPUs, and 64 GiB RAM, which is a good fit for a mid-complexity Isaac Sim digital twin project with factory assets, physics, and interactive iteration.
A few practical notes:
Use stop/start to manage cost. When stopped, Brev releases the GPU and preserves data in /home/ubuntu/workspace, with only storage costs remaining.
Keep your project files, USD assets, scripts, and notebooks under /home/ubuntu/workspace.
Push important work to Git or another remote backup before stopping, since GPU capacity in the same region/provider is not always guaranteed when restarting.
Do not delete the instance unless everything is backed up, because delete removes the instance data.
For the “local Isaac Sim” experience, the Brev/Launchable workflow should be the right path: Isaac Sim runs on the L40S VM and you interact through the browser/streamed UI. The main difference versus local is network latency, so choose a nearby region if available.
On student or internship discounts, I don’t have a discount code to share. Please contact your university or internship sponsor to find out whether any academic funding options are available.
