Bringing Up an Ethernet Interface Over PCIE
we want to boot the endpoint system and boot the root port system together.
We can configure the endpoint system according to the following methods
cd /sys/kernel/config/pci_ep/
mkdir functions/pci_epf_tvnet/func1
echo 16 > functions/pci_epf_tvnet/func1/msi_interrupts
ln -s functions/pci_epf_tvnet/func1 controllers/141a0000.pcie_ep/
echo 1 > controllers/141a0000.pcie_ep/start
At this time, we must restart the root port system now.So,we can find ethx.
We don’t want to restart.We tried the pcie-rescan method.It can not worked.
echo 1 > /sys/bus/pci/rescan
We also try to integrate pcie_ tegra.c is compiled into .ko module.But it also failed.
ERROR: “__dw_pcie_write_dbi” [drivers/pci/dwc/pcie-tegra.ko] undefined!
ERROR: “dw_pcie_ep_linkup” [drivers/pci/dwc/pcie-tegra.ko] undefined!
ERROR: “dw_pcie_set_regs_available” [drivers/pci/dwc/pcie-tegra.ko] undefined!
We’d like to ask if it’s possible to solve this problem other than restarting the root system.
Please use the following changes to fix the build issues with compiling the PCIe driver as a loadable module
diff --git a/drivers/pci/dwc/pcie-designware-ep.c b/drivers/pci/dwc/pcie-designware-ep.c
index 6424c6340ac7..0f6fe378dd4d 100644
--- a/drivers/pci/dwc/pcie-designware-ep.c
+++ b/drivers/pci/dwc/pcie-designware-ep.c
@@ -29,6 +29,7 @@ void dw_pcie_ep_linkup(struct dw_pcie_ep *ep)
        pci_epc_linkup(epc);
+EXPORT_SYMBOL(dw_pcie_ep_linkup);
 static void dw_pcie_ep_reset_bar(struct dw_pcie *pci, enum pci_barno bar)
@@ -307,6 +308,7 @@ void dw_pcie_set_regs_available(struct dw_pcie *pci)
        dw_pcie_writew_dbi(pci, MSI_MESSAGE_CONTROL, ep->cached_msi_ctrl);
        dw_pcie_dbi_ro_wr_dis(pci);
+EXPORT_SYMBOL(dw_pcie_set_regs_available);
 static int dw_pcie_ep_raise_irq(struct pci_epc *epc,
                                enum pci_epc_irq_type type, u8 interrupt_num)
diff --git a/drivers/pci/dwc/pcie-designware.c b/drivers/pci/dwc/pcie-designware.c
index e69b9f6fc21c..97f007ab752b 100644
--- a/drivers/pci/dwc/pcie-designware.c
+++ b/drivers/pci/dwc/pcie-designware.c
@@ -93,6 +93,7 @@ void __dw_pcie_write_dbi(struct dw_pcie *pci, void __iomem *base, u32 reg,
        if (ret)
                dev_err(pci->dev, "write DBI address failed\n");
+EXPORT_SYMBOL(__dw_pcie_write_dbi);
 static u32 dw_pcie_readl_ob_unroll(struct dw_pcie *pci, u32 index, u32 reg)
Thank you. I have compiled it
Hi jmumper2,
Please help to open a new topic if it’s still an issue. Thanks
