Broad-R Reach PX2
Hi All,
From the hardware quick start guide of the PX2 and from the cables supplied I see that there is a port which enables Broad-R Reach (Automotive Ethernet).
What are the possibilities of this port? Can it be used to send/receive messages equal to CAN, FlexRay and LIN or is it only to be used to connect a camera/ for debugging purposes?
I’m looking forward receiving your answer.
Best regards!
Dear info.logena,
Please check [url]https://docs.nvidia.com/drive/active/5.0.10.3L/nvvib_docs/index.html#page/NVIDIA%2520DRIVE%2520Linux%2520SDK%2520Development%2520Guide%2Fboard_p3407.html%23wwpID0EIHA[/url] for your topic.
Thank you for your quick reply.
I’ve had a look at the link you’ve send me, I’m wondering if it could also be used with an ECU supplied with an Automotive Ethernet port, this since the RAD-MOON has full duplex support?
Dear info.logena,
May I know if you have autochauffer or autocruise?
We have autochauffeur.
Can you specify the usage of the BroadR-Reach port already?
How I think of it, as the manual suggests while using RAD-MOON, is that processed data from NVIDIA PX2 can be send over BroadR-Reach and can be analysed using the RAD tool.
If this is the case, than I can also use these messages as an input for an ECU supporting BroadR-Reach.
Could you verify if this is correct?
