Broken frame image returned by get_nvds_buf_surface
Jetson Xavier AGX
• DeepStream Version
DeepStream 6.0
JetPack 4.6
question
The sample application is included. Substitute your rtsp or file uri in self.add_source() call on line 313 and run the script. The script writes frames into source_0.jpg file.
Python 3.x and OpenCV are required (I used Python 3.6.9 and OpenCV version 4.5.4, but I guess that other versions are acceptable).
I’m running a pipeline like the following:
gst-launch-1.0 -e \
        nvstreammux name=mux width=960 height=540 batch-size=1 live-source=1 \
        ! nvstreamdemux name=demux \
	uridecodebin uri=file:/home/zabra/workspace/streams/1.mp4 \
        ! videorate \
        ! nvvideoconvert ! "video/x-raw(memory:NVMM),format=RGBA,framerate=2/1" \
        ! queue \
        ! mux.sink_0 \
        demux.src_0 \
        ! queue \
        ! nvdsosd \
        ! nvegltransform \
        ! nveglglessink \
This is a test pipeline, the actual pipeline contains nvinfer and nvtracker between nvstreammux and nvstreamdemux.
I’m trying to get frame image using a buffer probe on nvdsosd src pad. However, when I decode the data returned by get_nvds_buf_surface() call, I see the broken image (just garbage on screen, black image etc…). Meanwhile nveglglessink shows correct frames and the pipeline works fine.
When I put an inference between the muxer and demuxer, I get broken images until the network detects a first object on video. As soon as a first object is detected, the frame images become normal.
I suppose I’m doing something wrong with the pipeline. Could you please help me to resolve the issue?
test_pipeline.py (11.7 KB)
Your code is wrong. The pipeline is not build successfully. Please refer to deepstream_python_apps/apps at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub for constructing pipeline with gst-python and deepstream.
