Browser does not launch when entering SDK Manager
Received the below warning
fpascal@ASUSzenbookPro:/mnt/c/users/fpasc/downloads$ sudo apt install ./sdkmanager_2.1.0-11682_amd64.deb
Reading package lists… Done
Building dependency tree
Reading state information… Done
Note, selecting ‘sdkmanager’ instead of ‘./sdkmanager_2.1.0-11682_amd64.deb’
The following additional packages will be installed:
at-spi2-core libatk-bridge2.0-0 libatspi2.0-0 libcanberra-gtk3-0 libcanberra-gtk3-module libcolord2 libepoxy0
libgbm1 libgtk-3-0 libgtk-3-bin libgtk-3-common liblcms2-2 librest-0.7-0 libsoup-gnome2.4-1 libwayland-cursor0
libwayland-egl1 libwayland-server0 libxkbcommon0
Suggested packages:
colord gvfs liblcms2-utils
The following NEW packages will be installed:
libwayland-egl1 libwayland-server0 libxkbcommon0 sdkmanager
0 upgraded, 19 newly installed, 0 to remove and 0 not upgraded.
Need to get 3783 kB of archives.
After this operation, 402 MB of additional disk space will be used.
W: Repository is broken: sdkmanager:amd64 (= 2.1.0-11682) has no Size information
Do you want to continue? [Y/n] y
Continued with the install. Ran sdkmanager command. Splash screen launched. Error message circled
SDK Manager log attached
sdkm-2024-06-30-10-15-17.log (4.3 KB)
So does the QR code method work?
I just tried on my host PC and SDKM is working fine.
