Using the Buffer of Buffer IDs, can you get access to a buffer of TextureSamplers in your shader programs?
I was trying to do something as follows.
Buffer buffers = m_context->createBuffer ( RT_BUFFER_INPUT, RT_FORMAT_BUFFER_ID, N) ;
context["buffers"] -> set(buffers) ;
int* buffers_data = static_cast<int*>( buffers -> map() );
for ( int i = 0; i < N; ++i ){
Buffer buffer = context->createBuffer ( RT_BUFFER_INPUT, RT_FORMAT_FLOAT , M ) ;
float* buffer_data = static_cast<float*>( buffer -> map() ) ;
for ( int j = 0; j < M; ++j ){
*buffer_data++ = /*float data*/ ;
TextureSampler sampler = context->createTextureSampler() ;
sampler -> setWrapMode (0, RT_WRAP_CLAMP_TO_EDGE);
sampler -> setFilteringModes (RT_FILTER_LINEAR, RT_FILTER_LINEAR, RT_FILTER_NONE);
sampler -> setIndexingMode (RT_TEXTURE_INDEX_NORMALIZED_COORDINATES);
sampler -> setReadMode (RT_TEXTURE_READ_ELEMENT_TYPE);
sampler -> setMaxAnisotropy ( 1.0f );
sampler -> setMipLevelCount ( 1u );
sampler -> setArraySize (1);
sampler -> setBuffer (0, 0, buffer);
*buffers_data++ = sampler -> getID() ;
buffers -> unmap()
SHADER PROGRAM
rtBuffer<rtBufferId<float,1>, 1> buffers;
RT_PROGRAM void shader_program()
// Was hoping it would work as such
float value = tex1D( buffers[index], query_value );
I was hoping something along these lines would work. The textures I want to use are actually 3D textures which is why I am attempting to use the Buffer of Buffer ID’s. Any suggestions?
