Bug: 570.133.07 & 570.124.04 "Pageflip timed out" on 5070 TI after using KDE screenshot tool after waking up from sleep
There seems to be an issue an issue trying to take partial screenshot of the screen (shortcut is: meta + shift + print scr) after computer and monitors wake up from sleep. The sleep is the important part, if you don’t put it to sleep, no issue. Attaching journalctl logs and screenshot of the fastfetch to give more info about my system.
Steps to reproduce:
  1. Put the computer to sleep. Monitors go to sleep / idle as a result as well
  2. Wake it up with the keyboard
  3. Try to take a partial screenshot of the screen.
Result:
Pageflip timed out. Monitors freeze. If you are lucky, only one monitor freezes and you can open a terminal to invoke reboot command on the second, otherwise you have to press the reboot button and do it the hard way.
Reproduce rate: 100%
journalctl logs:
logs.txt (113.1 KB)
Normally one would try an older driver, but I can’t do that since 570.124.04 is the first one that works with 5070 TI
