Hello. I am experiencing a fatal initialization failure with the Open Kernel Modules on a new Acer Predator laptop with an Intel Core Ultra 9 and an NVIDIA RTX 5070 Mobile (Blackwell). The HDMI port is wired directly to the dGPU and remains dead because the Display Engine fails to initialize.
Despite explicitly running the Open Kernel Modules and ensuring the GSP firmware is present in the initramfs, the driver fails during modesetting/GUI startup and paradoxically complains that the open modules are required.
Environment:
OS: openSUSE Tumbleweed
Kernel: 7.1.8-1-default
GPU: NVIDIA RTX 5070 Laptop GPU (PCI ID: 10de:2d58)
Driver Version: 580.159.03 (Open Kernel Module)
Kernel Parameters:
nvidia.NVreg_PreserveVideoMemoryAllocations=1 nvidia.NVreg_EnableS0ixPowerManagement=1 nvidia-drm.modeset=1 nvidia_drm.fbdev=1 i915.enable_psr=0
Symptoms & Logs:
The driver successfully loads initially during boot:
NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 580.159.03 -
Later in the boot process (when Wayland/Display Manager starts or HDMI is plugged in), the driver fails to read the EDID:
nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device DP-0 -
Immediately after, it throws a fatal fallback error, paradoxically asking for the open modules which are already loaded:
NVRM: The NVIDIA GPU 0000:02:00.0 (PCI ID: 10de:2d58)nvidia-bug-report.log.gz (1.8 MB)
dmsg.txt (114.5 KB)
NVRM: installed in this system requires use of the NVIDIA open kernel modules.NVRM: GPU 0000:02:00.0: RmInitAdapter failed! (0x22:0x56:897)NVRM: GPU 0000:02:00.0: rm_init_adapter failed, device minor number 0
Troubleshooting performed:
Confirmed that
kernel-firmware-nvidia-gspx-G06is synced and the correct GSP firmware (gsp_*.binversion 580.x) is explicitly included in theinitramfsviadracut. -
DPM was tested on both
0x00and0x02. -
Issue is 100% reproducible on boot.
Attached is the full dmesg log and nvidia-bug-report.log.gz for reference. Please advise if any specific ACPI dumps or GSP logs are needed for further debugging.
