[BUG] cgf helloworld sample nvsci+interprocess communication hangs with exception error
@SivaRamaKrishnaNV Thanks for your reply!
Yes, it’s ok for you to change the case from A to E.
May I ask the driveos version of your drive-orin-platform? In the last topic I saw you just use the DO6090, which has dw516 rather than the developer version DO6081+dw514. [BUG] sample_cgf_dwchannel from dw5.14 failed with stuck in inter-process-socket communication (nvidia.com)
I will double check the CASE B and Case C, and check the log you post.
Glad to see the issue repro, when should it be resolved, and in which release?
DRIVE 6.0.8.1
When will Case E issue be resolved? In which release?
There is no documentation about how to config the nvsci communication.
That’s why I ask in the forum.
Could you get the sample run based on the code base I shared to you?
All I need is a runnable correct example.
Please take the responsibility to provide the fixed cgf 1:N nvsci communication helloworld example.
@SivaRamaKrishnaNV @VickNV
https://forums.developer.nvidia.com/t/re-bug-cgf-helloworld-sample-nvsci-interprocess-communication-hangs-with-exception-error/296231?u=lizhensheng
That’s the private msg sent to me from @SivaRamaKrishnaNV
@VickNV Do you think that is an approiate response?
Today, I received below feedback on case E configuration for core team.
Just two comments from a quick look:
The error message “ChannelNvSciStreamParams: limiter maxPackets index out of range” might be caused by the connection parameter “limits”: -1. I don’t know why that was set in the first place, maybe try it without that key or set to a different (non-negative) value.
The values for “srcEndpoint” and “destEndpoint” look weird. Each should only contain the name of one endpoint - not two separated by a colon.
Can you check the suggestion and update?
Hi @lizhensheng ,
did you try the above suggestion receive from engineering team? Any update can be shared.
It looks to me like case E is not supported. I need to give try before coming to conclusion. I planned to try this week and update the thread.
If you want me to try, show me the sample telling me how I can edit the json.
The json schema shows no information(just a simple string object), so I really don’t know how would I try editing the json.
good point. The engineering team need to take a response to comfirm that.
appreciated, thanks.
Hi @lizhensheng ,
I tried below config changes and seems to work. could you confirm?
nvidia@tegra-ubuntu:~/samples3$ sudo ./bin/cgf_custom_nodes/example/runHelloworld.sh
[sudo] password for nvidia:
20240708_183413
20240708_183413
DW_TOP_PATH=/home/nvidia/samples3
RR_TOP_PATH=/usr/local/driveworks/bin
CGF_SYS_PATH=
RR_LOG_PATH=/home/nvidia/samples3/LogFolder/cgf_custom_nodes/Helloworld
RR_RUN_CFG_PATH=/home/nvidia/samples3/RunFolder/cgf_custom_nodes/Helloworld
DATA_PATH=/home/nvidia/samples3/data/cgf_custom_nodes
Current DISPLAY is :0.0
fs.mqueue.msg_max = 4096
|--> Tuning network stack
LD_LIBRARY_PATH: /home/nvidia/samples3/../../xlab/sysroot/lib:/usr/local/driveworks/bin/lib::/home/nvidia/samples3/lib
total 2920
drwxr-xr-x. 3 root root    4096 Aug 25  2023 .
drwxr-xr-x. 7 root root    4096 Aug 25  2023 ..
-r-xr-xr-x. 1 root root   53320 Jan  1  2000 CGFSyncControlClientLite
-r-xr-xr-x. 1 root root   42600 Jan  1  2000 CGFSyncServer
-r-xr-xr-x. 1 root root 1687256 Jan  1  2000 LoaderLite
drwxr-xr-x. 2 root root    4096 Aug 25  2023 SSM
-r-xr-xr-x. 1 root root   14728 Jan  1  2000 ScheduleManager
lrwxrwxrwx. 1 root root      19 Jan  1  2000 get_ssm_state -> ./SSM/get_ssm_state
-r-xr-xr-x. 1 root root   39872 Jan  1  2000 launcher
-r-xr-xr-x. 1 root root   27904 Jan  1  2000 libFaultHandler.so
-r-xr-xr-x. 1 root root   31096 Jan  1  2000 libRRSEHDetails.so
-r-xr-xr-x. 1 root root    8400 Jan  1  2000 libconnection_helper.so
-r-xr-xr-x. 1 root root  507384 Jan  1  2000 libschedule_manager.so
-r-xr-xr-x. 1 root root  131496 Jan  1  2000 libsensor_sync_server_shared.so
-r-xr-xr-x. 1 root root   53568 Jan  1  2000 sensor_sync_server
-r-xr-xr-x. 1 root root   14336 Jan  1  2000 stm_managed_client
-r-xr-xr-x. 1 root root  336552 Jan  1  2000 stm_master
lrwxrwxrwx. 1 root root      16 Jan  1  2000 vanillassm -> ./SSM/vanillassm
Running command: /usr/local/driveworks/bin/launcher --binPath=/usr/local/driveworks/bin --spec=/home/nvidia/samples3/graphs/cgf_custom_nodes/apps/example/appHelloworld/DWCGFHelloworld.app.json --logPath=/home/nvidia/samples3/LogFolder/cgf_custom_nodes/Helloworld --path=/usr/local/driveworks/bin --datapath=/home/nvidia/samples3/data/cgf_custom_nodes --dwdatapath=/home/nvidia/samples3/data --schedule=/home/nvidia/samples3/bin/cgf_custom_nodes/DWCGFHelloworld__standardSchedule.stm --start_timestamp=0 --mapPath=maps/sample/sanjose_loop --loglevel=DW_LOG_VERBOSE --fullscreen=1 --winSizeW=1280 --winSizeH=800 --virtual=0 --disableStmControlLogger=1 --gdb_debug=0 --app_parameter= --useLCM=0 --memTraceEnabled=1 --stmControlTracing=0 --traceChannelMask=0xFFFFFFFF --traceFilePath=/home/nvidia/samples3/LogFolder/cgf_custom_nodes/Helloworld --traceLevel=0 > /home/nvidia/samples3/LogFolder/cgf_custom_nodes/Helloworld/launcher.log 2>&1
Check if reset NetworkStack needed
Restore LD_LIBRARY_PATH to
launcher exit status: 0
Graphlet.Json
root@6.0.8.1-0006-build-linux-sdk:/home/nvidia/GAC/nv_driveworks/driveworks-5.14/samples/src/cgf_nodes/graphs/apps/example/appHelloworld# cat DWCGFHelloworld.graphlet.json
    "name": "DWCGFHelloworld",
    "inputPorts": {},
    "outputPorts": {},
    "parameters": {
        "paraName": { "type": "std::string", "default": "helloworld_name" }
    "subcomponents": {
        "helloWorldNode": {
            "componentType": "../../../nodes/example/helloworld/HelloWorldNode.node.json",
            "parameters": {
                "name": "$paraName"
        "multipleNode": {
            "componentType": "../../../nodes/example/helloworld/MultipleNode.node.json"
        "sumNode": {
            "componentType": "../../../nodes/example/helloworld/SumNode.node.json"
    "connections": [
            "src": "helloWorldNode.VALUE_0",
            "dests": {
                "sumNode.VALUE_0": {
                    "mailbox": true,
                    "reuse": true
                "multipleNode.VALUE_0": {
                    "mailbox": true,
                    "reuse": true
            "src": "helloWorldNode.VALUE_1",
            "dests": {
                "sumNode.VALUE_1": {
                    "mailbox": true,
                    "srcEndpoint": "nvscistream_4",
                    "destEndpoint": "nvscistream_5",
                    "reuse": true
                "multipleNode.VALUE_1": {
                    "mailbox": true,
                    "srcEndpoint": "nvscistream_6",
                    "destEndpoint": "nvscistream_7",
                    "reuse": true
            "params": {
                "type": "nvsci"
Dear @lizhensheng,
Did you get chance to check ? Please update your observation after test.
I will give it a test in a week. Thanks.
@SivaRamaKrishnaNV Hey, thanks for you configration!
Your config was tested by me and it workded with nvsci 1:N transport.
The nvsci transport for POD datatype was tested in this topic, and I will close this thread, create a new topic for Non POD transport.
