Bug report and files:
https://github.com/mc-imperial/shader-compiler-bugs/issues/16
Fragment shader: the associated fragment shader is large, so I won’t paste it, but it can be found here:
This is accepted by glslangValidator and by a recent Intel driver, but the NVIDIA compiler gives an internal error, a snippet of which is:
Internal error: assembly compile error for fragment shader at offset 5906:
-- error message --
line 309, column 7: error: IF statement nested too deeply.
line 347, column 6: error: ENDIF without matching IF.
-- internal assembly text --
!!NVfp5.0
OPTION NV_bindless_texture;
# cgc version 3.4.0001, build date Oct 1 2016
# command line args:
#vendor NVIDIA Corporation
#version 3.4.0.1 COP Build Date Oct 1 2016
#profile gp5fp
#program main
#semantic injectionSwitch
#var float2 injectionSwitch : : c[0] : -1 : 1
PARAM c[1] = { program.local[0] };
TEMP R0;
TEMP RC, HC;
SGT.F R0.y, c[0].x, {1, 0, 0, 0}.x;
TRUNC.U.CC HC.x, R0.y;
MOV.U R0.x, {1, 0, 0, 0};
IF NE.x;
MOV.U R0.x, {0, 0, 0, 0};
ENDIF;
MOV.U.CC RC.x, R0;
IF NE.x;
SGT.F R0.y, {1, 0, 0, 0}.x, c[0];
IF NE.x;
IF NE.x;
It’s a very large shader and I doubt anyone would write a shader with so many conditionals in practice, so perhaps it’s OK for the compiler to reject this. But the error message is an internal error, with lots of low-level code output; it would be more graceful to complain about nesting depth at the source level.
In fact, although there are a lot of conditionals, the nesting is not deep.
- Operating system version.
Windows 10
- Graphics hardware.
GeForce GTX 770. Driver: 373.06
Reproducer project.
We have provided the fragment shader at the above link. -
Description of single steps to reproduce the problem.
Compile and link the fragment shader. -
Description of the expected result.
No link error.
