Still, despite all that, the setup fails to install the pertinent components claiming that it cannot find .NET 3.5 SP1:
Not Installed:
- Nsight Monitor and HUD Launcher
Reason: .NET 3.5 SP1 was not found
On a side note, this information is only shown after the setup is “complete”, instead of running the detection beforehand, which isn’t really nice from the UX POV.
All components of CUDA 5.5 production can be installed successfully on my clean windows server 2012 system.You can try to uninstall all components of cuda 5.5,then install again(not just overwrite install),see the problem will be gone or not.
I have uninstalled CUDA Toolkit 5.5 from the Add/Remove Programs component, and have subsequently reinstalled it. The exact same bug happens, the setup fails to detect .NET 3.5 SP1, even though it is definitely present.
The following steps should solve the Nsight issue.
Verify the following regkey is present.
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\NET Framework Setup\NDP\v3.5
It should contain a REG_DWORD entry called “SP”. The value should be “0x00000001 (1)”. If it’s not present, .NET 3.5 SP1 is not installed properly.
Uninstall Nsight Visual Studio Edition 3.1 directly from Add/Remove Programs
Uninstall CUDA Toolkit 5.5 from Add/Remove Programs
Re-install CUDA Toolkit 5.5
That should solve your issue.
Sorry for the inconvenience. The reason why Nsight is not updated after uninstalling CUDA Toolkit is due to Nsight being a separate product. The CUDA 5.5 install runs the Nsight installer silently and will only update the full product if the versioning is different. I recommend signing up for the Nsight Visual Studio Edition Registered Developer Program to obtain the standalone Nsight package. Sign up for free here: https://developer.nvidia.com/nvidia-nsight-visual-studio-edition-registered-developer-program
