Sorry for my English, this bug is a little complicated for me to describe, so I attached a sample code, hope it can help.
Basically, the bug involves following steps:
- in Vulkan, create a VkDeviceMemory which is large(like 2048x2048), export it with extension VK_KHR_external_memory_fd.
- in EGL/OpenGL ES, import the VkDeviceMemory with glCreateMemoryObjectEXT and glImportMemoryFdEXT
- in EGL/OpenGL ES, bind different portions of VkDeviceMemory to several smaller GL_TEXTURE_2D objects, like below
glTexStorageMem2DEXT(GL_TEXTURE_2D, 1, GL_RGBA8, width, height, memoryObject, offset);
here the width/height are smaller(eg. 4x4), offset is aligned to alignment which is calculated by vkGetImageMemoryRequirements, and the textures are guaranteed not to overlap with each other. - create EGLImage from these textures with:
eglCreateImageKHR(display, context, EGL_GL_TEXTURE_2D_KHR, reinterpret_cast(texture), nullptr);
I can confirm the first 3 steps are executed correctly and the textures created in step 3 can be used inside OpenGL without any problems. however the EGLImage created in step4 seems ignore the offset parameter specified in step 3. no matter which offset parameter i specified, the result EGLImage seems always point to the beginning of VkDeviceMemory, I believe this is not the correct behavior.
I can reproduce this problem under Ubuntu 16.04, driver 384.90 and 390.42, with GeForce 1050 and Quadro P2000.
The sample code can be found at:
https://gist.github.com/lamianlbe/ae09b83b2a93e1d1ae0c50f16aef9ebb
