I think I have found a bug in cutil.cpp.
CUTBoolean CUTIL_API
cutSavePPM4ub( const char* file, unsigned char *data,
unsigned int w, unsigned int h)
// strip 4th component
int size = w * h;
unsigned char *ndata = (unsigned char*) malloc( sizeof(unsigned char) * size*3);
unsigned char *ptr = ndata;
for(int i=0; i<size; i++) {
*ptr++ = *data++;
*ptr++ = *data++;
*ptr++ = *data++;
data++;
return savePPM( file, ndata, w, h, 3);;
Unless I’m using the function incorrectly, this implementation creates a memory leak. I am currently repeatedly calling CheckRender::savePPM, which calls cutSavePPM4ub, to save a series of images to make into a movie. If that is an incorrect approach, please let me know so I can do something better.
To resolve the memory leak, I added two lines to the end of the function.
int size = w * h;
*ptr++ = *data++;
*ptr++ = *data++;
*ptr++ = *data++;
data++;
CUTBoolean returner = savePPM( file, ndata, w, h, 3);
free(ndata);
return returner;
