I got an error while compiling
NVFORTRAN-S-0095-Expression has wrong data type (file:line)
for this statement:
out = omp_test_nest_lock (lock) .gt. 0
which I could not understand, since according to the OpenMP standard omp_test_nest_lock should return an integer.
Digging in to the files I see that in the interface file omp_lib.h the function is defined as
function omp_test_nest_lock(nvar) &
& bind(c, name='omp_test_nest_lock_')
import
integer (kind=omp_nest_lock_kind), intent(inout) :: nvar
logical (kind=omp_logical_kind) omp_test_nest_lock
end function omp_test_nest_lock
but I believe it should be
import
integer (kind=omp_integer_kind) omp_test_nest_lock
See the OpenMP standard: omp_test_lock and omp_test_nest_lock
I havde checked all the NVHPC compiler versions we have on the system: 21.5 21.7 22.5 23.5 24.1 24.5 and it is present in all of them
