Bug in GLSL linker
I’m trying to link the following shaders:
https://gist.github.com/SimonDanisch/15310093c91b494c3dd66b4a7c6b4bee#file-shader-glsl
Sorry, this is Julia code and I can’t create a C example right now.
I guess it should be possible for the driver team to compile them in the way they are ;)
For sanity, I copy and pasted my compilation and linker code from my higher level library.
The error is:
“struct geom_in not declared as output”
I confirmed that the exact same code is working with AMD and intel hardware!
Platform:
GTX 950
Driver: 382.53
Windows 10 64 bit (Also tested on Ubuntu 16.04 LTS)
Best,
Simon
Okay, found the problem!
I don’t actually call the main program, so I don’t write to geom_out and don’t emit any vertices.
Would it be possible to generate a better error message? “struct geom_in not declared as output” is very confusing, especially when it compiles on other hardware.
Also, I think this should actually be moved to OpenGL programming ;)
