As part of our testing of various RedHawk kernel flavors, we see that the debug kernel produces below backtrace earlier in the boot sequence.
[ 0.210261] DEBUG_LOCKS_WARN_ON(!p->hardirqs_enabled)
[ 0.210297] ------------[ cut here ]------------
[ 0.210337] WARNING: CPU: 0 PID: 0 at kernel/fork.c:1627 copy_process.isra.5.part.6+0x704/0x1940
[ 0.210389] Modules linked in:
[ 0.210412]
[ 0.210428] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.9.201-rt134-r32.5.1-tegra-RedHawk-7.5.4-rt-debug #21
[ 0.210485] Hardware name: quill (DT)
[ 0.210509] task: ffffff800a154f00 task.stack: ffffff800a140000
[ 0.210546] PC is at copy_process.isra.5.part.6+0x704/0x1940
[ 0.210580] LR is at copy_process.isra.5.part.6+0x704/0x1940
[ 0.210614] pc : [<ffffff80080ab0f4>] lr : [<ffffff80080ab0f4>] pstate: 60400045
[ 0.210657] sp : ffffff800a143d70
[ 0.210679] x29: ffffff800a143d70 x28: 0000000000800300
[ 0.210716] x27: ffffff800b7f5000 x26: 0000000000000000
[ 0.210754] x25: ffffff80090e6110 x24: 0000000000000000
[ 0.210790] x23: 0000000000000000 x22: ffffffc1ec698000
[ 0.210826] x21: 0000000000000000 x20: ffffff80080ac4cc
[ 0.210862] x19: ffffff800a149000 x18: ffffffffffffffff
[ 0.210898] x17: 0000000000000010 x16: 0000000000000000
[ 0.210933] x15: ffffff800a149fd0 x14: ffffff808b7f5b9f
[ 0.210974] x13: ffffff800b7f5bad x12: 0000000000000000
[ 0.211012] x11: 0000000005f5e0ff x10: 0000000000000069
[ 0.211051] x9 : 00000000ffffffd0 x8 : 64656c62616e655f
[ 0.211090] x7 : 000000000000006d x6 : ffffff80081325a4
[ 0.211129] x5 : 0000000000000000 x4 : 0000000000000000
[ 0.211168] x3 : 0000000000000000 x2 : ffffffffffffffff
[ 0.211206] x1 : ffffff800a14a0b0 x0 : 0000000000000029
[ 0.211245]
[ 0.211263] ---[ end trace 7c274a1c59fae664 ]---
[ 0.211295] Call trace:
[ 0.211318] [<ffffff80080ab0f4>] copy_process.isra.5.part.6+0x704/0x1940
[ 0.211362] [<ffffff80080ac4cc>] _do_fork+0xd4/0x5c0
[ 0.211397] [<ffffff80080aca60>] kernel_thread+0x48/0x90
[ 0.211436] [<ffffff80090e60ac>] rest_init+0x2c/0x90
[ 0.211474] [<ffffff8009870c40>] start_kernel+0x40c/0x424
[ 0.211510] [<ffffff8009870204>] __primary_switched+0x80/0x94
This is occurring because there’s a missing lockdep_on()
call in kernel/printk/printk.c file after the application of the rt-patches/* . Possible fix to the rt-patches/0246-printk-Make-rt-aware.patch
is as below:
Index: a/kernel-4.9/kernel/printk/printk.c
--- a.orig/kernel-4.9/kernel/printk/printk.c
+++ a/kernel-4.9/kernel/printk/printk.c
@@ -1939,6 +1939,7 @@ asmlinkage int vprintk_emit(int facility
if (may_trylock && console_trylock())
console_unlock();
+ lockdep_on();
return printed_len;
Please note that the above backtrace happens on non-PRT kernels as well if the rt-patches/* are applied but CONFIG_PREEMPT_RT_FULL
is not set. Also, this is happening on other jetson boards as well and not just TX2. I found it on a TX2 first hence reporting here.
