[BUG] No HDR on Projector, works on Windows 11 (KDE Plasma 6.8 Wayland)
On KDE Plasma 6.8 (Wayland), enabling HDR - or only wide color gamut - on an HDMI-connected Epson projector fails with “The driver rejected the output configuration”. The same projector does HDR on Windows 11 with the same GPU, port and cable, and another display does HDR over the same HDMI port under Linux.
Setup: RTX 4090, Arch Linux, KDE Plasma 6.8.0 / KWin 6.8.0 (Wayland), nvidia-open 615.78.08. Main monitor on DP-1 (EDID name “PD32M”, 4K144), projector on HDMI-A-1 (EDID name “EPSON PJ”).
Works
  • Main monitor: HDR at 3840x2160@144 over DP-1.
  • The same monitor on the HDMI port: HDR at 3840x2160@144.
  • Projector with HDR on Windows 11 (same GPU, port and cable).
Fails
  • HDR on the projector at 3840x2160@60 and at 1920x1080@60.
  • Wide color gamut only (Colorspace=BT2020_RGB, no HDR metadata): also rejected.
  • With only the projector connected to the HDMI port: still rejected.
  • With the main monitor disabled in KDE: still rejected.
  • With the main monitor at 4K60 and HDR off: still rejected.
  • Changing the projector’s menu options (colorspace, dynamic range, video range) changes neither the EDID nor the result.
The projector’s EDID declares BT.2020 RGB/YCC, HDR10 + HLG, HDMI 2.0 (600 MHz TMDS, SCDC) and 10/12-bit deep color (full decode below). The connector exposes Colorspace, HDR_OUTPUT_METADATA and NV_HDMI_VSIF_METADATA, but no max_bpc. KWin logs GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT and “Failed to find a working output layer configuration”.
Questions: Why is the atomic commit rejected for this sink, and can the driver log the reason? Does the driver fall back to a YCbCr format on HDMI when RGB is not possible, and should KWin request BT2020_YCC in that case?
nvidia-bug-report.log.gz (taken right after a failed attempt) is attached.
Versions
7.2.11-arch1-1
nvidia-open 615.78.08-3
nvidia-utils 615.78.08-1
kwin 6.8.0-1
plasma-desktop 6.8.0-1
NVIDIA GeForce RTX 4090, 615.78.08
Error output
applying config failed! The driver rejected the output configuration: %s(I18N_EXCESS_ARGUMENTS_SUPPLIED)
[details=“KWin log (condensed)”]
     72 kwin_wayland[1050]: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
      1 kwin_wayland[1050]: 1 instead of 0 arguments to message "The driver rejected ..." supplied before conversion
      6 kwin_wayland[1050]: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
      1 kwin_wayland[1050]: Failed to find a working output layer configuration: preparing rendering failed
     12 kwin_wayland[1050]: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
[/details]
[details=“dmesg (nvidia/drm lines)”]
[13178.709103] [drm] [nvidia-drm] Infoframe changed on CRTC 0 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13178.709848] [drm] [nvidia-drm] Infoframe changed on CRTC 1 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13178.710573] [drm] [nvidia-drm] Infoframe changed on CRTC 3 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13178.711305] [drm] [nvidia-drm] Infoframe changed on CRTC 0 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13178.711932] [drm] [nvidia-drm] Infoframe changed on CRTC 1 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13178.712520] [drm] [nvidia-drm] Infoframe changed on CRTC 2 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13232.029769] [drm] [nvidia-drm] Infoframe changed on CRTC 0 (hdr=1 colorspace=0 vsif=0), adding planes on CRTC to atomic commit
[13232.031509] [drm] [nvidia-drm] Infoframe changed on CRTC 2 (hdr=1 colorspace=0 vsif=0), adding planes on CRTC to atomic commit
[13232.032915] [drm] [nvidia-drm] Infoframe changed on CRTC 3 (hdr=1 colorspace=0 vsif=0), adding planes on CRTC to atomic commit
[13232.034119] [drm] [nvidia-drm] Infoframe changed on CRTC 1 (hdr=1 colorspace=0 vsif=0), adding planes on CRTC to atomic commit
[13232.035180] [drm] [nvidia-drm] Infoframe changed on CRTC 2 (hdr=1 colorspace=0 vsif=0), adding planes on CRTC to atomic commit
[13232.036126] [drm] [nvidia-drm] Infoframe changed on CRTC 3 (hdr=1 colorspace=0 vsif=0), adding planes on CRTC to atomic commit
[13232.037129] [drm] [nvidia-drm] Infoframe changed on CRTC 0 (hdr=1 colorspace=0 vsif=0), adding planes on CRTC to atomic commit
[13232.038118] [drm] [nvidia-drm] Infoframe changed on CRTC 1 (hdr=1 colorspace=0 vsif=0), adding planes on CRTC to atomic commit
[13232.039107] [drm] [nvidia-drm] Infoframe changed on CRTC 3 (hdr=1 colorspace=0 vsif=0), adding planes on CRTC to atomic commit
[13232.040096] [drm] [nvidia-drm] Infoframe changed on CRTC 0 (hdr=1 colorspace=0 vsif=0), adding planes on CRTC to atomic commit
[13232.041091] [drm] [nvidia-drm] Infoframe changed on CRTC 1 (hdr=1 colorspace=0 vsif=0), adding planes on CRTC to atomic commit
[13232.042134] [drm] [nvidia-drm] Infoframe changed on CRTC 2 (hdr=1 colorspace=0 vsif=0), adding planes on CRTC to atomic commit
[13232.251511] [drm] [nvidia-drm] Infoframe changed on CRTC 0 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13232.253104] [drm] [nvidia-drm] Infoframe changed on CRTC 2 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13232.254572] [drm] [nvidia-drm] Infoframe changed on CRTC 3 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13232.255589] [drm] [nvidia-drm] Infoframe changed on CRTC 1 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13232.256545] [drm] [nvidia-drm] Infoframe changed on CRTC 2 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13232.257573] [drm] [nvidia-drm] Infoframe changed on CRTC 3 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13232.258496] [drm] [nvidia-drm] Infoframe changed on CRTC 0 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13232.259488] [drm] [nvidia-drm] Infoframe changed on CRTC 1 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13232.260445] [drm] [nvidia-drm] Infoframe changed on CRTC 3 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13232.261441] [drm] [nvidia-drm] Infoframe changed on CRTC 0 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13232.262425] [drm] [nvidia-drm] Infoframe changed on CRTC 1 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[13232.263400] [drm] [nvidia-drm] Infoframe changed on CRTC 2 (hdr=0 colorspace=1 vsif=0), adding planes on CRTC to atomic commit
[/details]
[details=“DRM connector properties (modetest)”]
828	827	connected	HDMI-A-1       	0x0		23	827
    831 Colorspace:
    8 HDR_OUTPUT_METADATA:
    58 NV_HDMI_VSIF_METADATA:
833	832	connected	DP-1           	700x390		34	832, 835
    834 Colorspace:
837	0	disconnected	HDMI-A-2       	0x0		0	836
    838 Colorspace:
840	0	disconnected	DP-2           	0x0		0	839, 842
    841 Colorspace:
844	0	disconnected	DP-3           	0x0		0	843, 846
    845 Colorspace:
[/details]
[details=“kscreen-doctor -o”]
Output: 1 HDMI-A-1 86c46cce-15ee-4ec9-b567-6e74b3fd153c
    enabled
    connected
    priority 2
    HDMI
    replication source:0
    Modes:  1:3840x2160@60.00*!  2:4096x2160@59.94  3:4096x2160@50.00  4:4096x2160@29.97  5:4096x2160@25.00  6:4096x2160@24.00  7:4096x2160@23.98  8:3840x2160@59.94  9:3840x2160@50.00  10:3840x2160@29.97  11:3840x2160@25.00  12:3840x2160@23.98  13:1920x1080@60.00  14:1920x1080@59.94  15:1920x1080@50.00  16:1920x1080@29.97  17:1920x1080@23.98  18:1280x720@59.94  19:1280x720@50.00  20:720x576@50.00  21:720x480@59.94  22:640x480@59.94  23:640x480@59.93
	Custom modes: None
	Geometry: 0,1728 1920x1080
	Scale: 2
	Rotation: 1
	Overscan: 0
	Vrr: Never
	RgbRange: unknown
	HDR: disabled
	Wide Color Gamut: disabled
	ICC profile: none
	Color profile source: EDID
	Color power preference: prefer accuracy
	Brightness control: supported, set to 100% and dimming to 100%
	Color resolution: unknown
	Allow EDR: unsupported
	Sharpness control: unsupported
	Automatic brightness: unsupported
	Auto Rotate Policy: incapable
	Adaptive backlight modulation: unsupported
Output: 2 DP-1 34639998-3cbd-4a09-9e49-a75428995ad2
    enabled
    connected
    priority 1
    DisplayPort
    Modes:  24:3840x2160@60.00!  25:3840x2160@143.98*  26:3840x2160@119.99  27:3840x2160@97.98  28:1920x2160@59.99  29:2560x1440@143.91  30:2560x1440@120.00  31:1920x1080@119.88  32:1920x1080@60.00  33:1920x1080@59.94  34:1920x1080@50.00  35:1280x1024@75.03  36:1280x1024@60.02  37:1280x720@59.94  38:1280x720@50.00  39:1024x768@119.99  40:1024x768@99.97  41:1024x768@75.03  42:1024x768@70.07  43:1024x768@60.00  44:800x600@119.97  45:800x600@99.66  46:800x600@75.00  47:800x600@72.19  48:800x600@60.32  49:800x600@56.25  50:720x576@50.00  51:720x480@59.94  52:640x480@119.52  53:640x480@99.77  54:640x480@75.00  55:640x480@72.81  56:640x480@59.94  57:640x480@59.93
	Custom modes: None
	Geometry: 0,0 3072x1728
	Scale: 1.25
	Rotation: 1
	Overscan: 0
	Vrr: Never
	RgbRange: unknown
	HDR: enabled
		SDR brightness: 750 nits
		SDR gamut wideness: 0%
		Peak brightness: 1671 nits, overridden with: 1310 nits
		Max average brightness: 1207 nits
		Min brightness: 0.0504 nits
		HDR color profile source: EDID
		HDR ICC profile: none
	Wide Color Gamut: enabled
	ICC profile: none
	Color profile source: sRGB
	DDC/CI: allowed
[/details]
[details=“Projector EDID (edid-decode)”]
edid-decode (hex):
00 ff ff ff ff ff ff 00 4c a3 07 a8 01 01 01 01
1b 1d 01 03 80 00 00 78 0e de 50 a3 54 4c 99 26
0f 50 54 20 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 08 e8 00 30 f2 70 5a 80 b0 58
8a 00 40 84 63 00 00 1e 02 3a 80 18 71 38 2d 40
58 2c 45 00 40 84 63 00 00 1e 00 00 00 fd 00 18
55 0f 87 3c 00 0a 20 20 20 20 20 20 00 00 00 fc
00 45 50 53 4f 4e 20 50 4a 0a 20 20 20 20 01 18
02 03 55 f2 5b 61 60 5f 5e 5d 66 65 64 63 62 10
1f 20 04 13 22 05 14 03 02 12 11 07 06 16 15 01
23 09 07 07 83 01 00 00 76 03 0c 00 10 00 b8 3c
e0 2e 2e 21 ff c0 84 01 02 03 04 01 00 7c 00 67
d8 5d c4 01 78 80 03 e3 05 c0 00 e2 00 fb e2 0f
63 e3 06 0d 01 01 3a 80 d0 72 38 2d 40 10 2c 45
80 40 84 63 00 00 1e 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06
Block 0, Base EDID:
  EDID Structure Version & Revision: 1.3
  Vendor & Product Identification:
    Manufacturer: SEC
    Model: 43015
    Serial Number: 16843009 (0x01010101)
    Made in: week 27 of 2019
  Basic Display Parameters & Features:
    Digital display
    Image size is variable
    Gamma: 2.20
    RGB color display
    Default (sRGB) color space is primary color space
    First detailed timing is the preferred timing
  Color Characteristics:
    Red  : 0.6396, 0.3291
    Green: 0.2998, 0.5996
    Blue : 0.1494, 0.0595
    White: 0.3125, 0.3281
  Established Timings I & II:
    DMT 0x04:   640x480    59.940476 Hz   4:3     31.469 kHz     25.175000 MHz
  Standard Timings: none
  Detailed Timing Descriptors:
    DTD 1:  3840x2160   60.000000 Hz  16:9    135.000 kHz    594.000000 MHz (1600 mm x 900 mm)
                 Hfront  176 Hsync  88 Hback  296 Hpol P
                 Vfront    8 Vsync  10 Vback   72 Vpol P
    DTD 2:  1920x1080   60.000000 Hz  16:9     67.500 kHz    148.500000 MHz (1600 mm x 900 mm)
                 Hfront   88 Hsync  44 Hback  148 Hpol P
                 Vfront    4 Vsync   5 Vback   36 Vpol P
    Display Range Limits:
      Monitor ranges (GTF): 24-85 Hz V, 15-135 kHz H, max dotclock 600 MHz
    Display Product Name: 'EPSON PJ'
  Extension blocks: 1
Checksum: 0x18
Block 1, CTA-861 Extension Block:
  Revision: 3
  Underscans IT Video Formats by default
  Basic audio support
  Supports YCbCr 4:4:4
  Supports YCbCr 4:2:2
  Native detailed modes: 2
  Video Data Block:
    VIC  97:  3840x2160   60.000000 Hz  16:9    135.000 kHz    594.000000 MHz
    VIC  96:  3840x2160   50.000000 Hz  16:9    112.500 kHz    594.000000 MHz
    VIC  95:  3840x2160   30.000000 Hz  16:9     67.500 kHz    297.000000 MHz
    VIC  94:  3840x2160   25.000000 Hz  16:9     56.250 kHz    297.000000 MHz
    VIC  93:  3840x2160   24.000000 Hz  16:9     54.000 kHz    297.000000 MHz
    VIC 102:  4096x2160   60.000000 Hz 256:135  135.000 kHz    594.000000 MHz
    VIC 101:  4096x2160   50.000000 Hz 256:135  112.500 kHz    594.000000 MHz
    VIC 100:  4096x2160   30.000000 Hz 256:135   67.500 kHz    297.000000 MHz
    VIC  99:  4096x2160   25.000000 Hz 256:135   56.250 kHz    297.000000 MHz
    VIC  98:  4096x2160   24.000000 Hz 256:135   54.000 kHz    297.000000 MHz
    VIC  16:  1920x1080   60.000000 Hz  16:9     67.500 kHz    148.500000 MHz
    VIC  31:  1920x1080   50.000000 Hz  16:9     56.250 kHz    148.500000 MHz
    VIC  32:  1920x1080   24.000000 Hz  16:9     27.000 kHz     74.250000 MHz
    VIC   4:  1280x720    60.000000 Hz  16:9     45.000 kHz     74.250000 MHz
    VIC  19:  1280x720    50.000000 Hz  16:9     37.500 kHz     74.250000 MHz
    VIC  34:  1920x1080   30.000000 Hz  16:9     33.750 kHz     74.250000 MHz
    VIC   5:  1920x1080i  60.000000 Hz  16:9     33.750 kHz     74.250000 MHz
    VIC  20:  1920x1080i  50.000000 Hz  16:9     28.125 kHz     74.250000 MHz
    VIC   3:   720x480    59.940060 Hz  16:9     31.469 kHz     27.000000 MHz
    VIC   2:   720x480    59.940060 Hz   4:3     31.469 kHz     27.000000 MHz
    VIC  18:   720x576    50.000000 Hz  16:9     31.250 kHz     27.000000 MHz
    VIC  17:   720x576    50.000000 Hz   4:3     31.250 kHz     27.000000 MHz
    VIC   7:  1440x480i   59.940060 Hz  16:9     15.734 kHz     27.000000 MHz
    VIC   6:  1440x480i   59.940060 Hz   4:3     15.734 kHz     27.000000 MHz
    VIC  22:  1440x576i   50.000000 Hz  16:9     15.625 kHz     27.000000 MHz
    VIC  21:  1440x576i   50.000000 Hz   4:3     15.625 kHz     27.000000 MHz
    VIC   1:   640x480    59.940476 Hz   4:3     31.469 kHz     25.175000 MHz
  Audio Data Block:
    Linear PCM:
      Max channels: 2
      Supported sample rates (kHz): 48 44.1 32
      Supported sample sizes (bits): 24 20 16
  Speaker Allocation Data Block:
    FL/FR - Front Left/Right
  Vendor-Specific Data Block (HDMI), OUI 00-0C-03:
    Source physical address: 1.0.0.0
    Supports_AI
    DC_36bit
    DC_30bit
    DC_Y444
    Maximum TMDS clock: 300 MHz
    Video latency: 90 ms
    Audio latency: 90 ms
    Interlaced video latency: 64 ms
    Interlaced audio latency: Audio not supported
    Extended HDMI video details:
      3D present
      3D-capable-VIC mask present
      HDMI VICs:
        HDMI VIC 1:  3840x2160   30.000000 Hz  16:9     67.500 kHz    297.000000 MHz
        HDMI VIC 2:  3840x2160   25.000000 Hz  16:9     56.250 kHz    297.000000 MHz
        HDMI VIC 3:  3840x2160   24.000000 Hz  16:9     54.000 kHz    297.000000 MHz
        HDMI VIC 4:  4096x2160   24.000000 Hz 256:135   54.000 kHz    297.000000 MHz
      3D: Side-by-side (half, horizontal)
      3D VIC indices that support these capabilities:
  Vendor-Specific Data Block (HDMI Forum), OUI C4-5D-D8:
    Version: 1
    Maximum TMDS Character Rate: 600 MHz
    SCDC Present
    Supports 12-bits/component Deep Color 4:2:0 Pixel Encoding
    Supports 10-bits/component Deep Color 4:2:0 Pixel Encoding
  Colorimetry Data Block:
    BT2020YCC
    BT2020RGB
  Video Capability Data Block:
    YCbCr quantization: Selectable (via AVI YQ)
    RGB quantization: Selectable (via AVI Q)
    PT scan behavior: Supports both over- and underscan
    IT scan behavior: Always Underscanned
    CE scan behavior: Supports both over- and underscan
  YCbCr 4:2:0 Capability Map Data Block:
  HDR Static Metadata Data Block:
    Electro optical transfer functions:
      Traditional gamma - SDR luminance range
      SMPTE ST2084
      Hybrid Log-Gamma
    Supported static metadata descriptors:
      Static metadata type 1
    DTD 3:  1920x1080   49.996633 Hz  16:9     56.246 kHz    148.490000 MHz (1600 mm x 900 mm)
                 Hfront  528 Hsync  44 Hback  148 Hpol P
Checksum: 0x06  Unused space in Extension Block: 24 bytes
[/details]
I tracked this down on an RTX 5090 + HDMI projector (615.78.08, KWin 6.8): the driver rejects HDR for every HDMI sink that advertises 3D in its EDID. Nearly all projectors do. nvDpyIsHDRCapable() in nvidia-modeset has if (pInfo->HDMI3DSupported) return FALSE;. The KWin GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT errors are only a consequence of that rejection.
On Blackwell (RTX 50xx) this check is unnecessary, because the HDR and 3D infoframes have separate slots there. With a one-line patch to the open kernel module, HDR works on the projector at 4K60. Report and patch: HDR always rejected on HDMI 3D-capable sinks (projectors) on Blackwell, although infoframes are not shared · Issue #1475 · NVIDIA/open-gpu-kernel-modules · GitHub
On RTX 40xx and older, the two infoframes share a slot, so this patch does not help there. NVIDIA would need to handle that case differently (e.g. allow HDR while no 3D mode is active). If your projector has an option to turn off 3D or change the HDMI EDID mode, it may be worth a try.
Update (doesn’t fix it):
I removed the HDMI 3D bits from the projector’s EDID and loaded it with drm.edid_firmware=HDMI-A-1:… (UKI, Secure Boot). /sys/class/drm/*/edid shows the patched EDID (no 3D), but kscreen-doctor output.HDMI-A-1.hdr.enable is still rejected. So the check in nvidia-modeset apparently uses the sink’s own EDID and ignores the DRM override. For pre-Blackwell GPUs, a fix would have to allow HDR on 3D-capable sinks (e.g. while no 3D mode is active) or honor the override.
Also putting projector in 2D mode unfortunately doesn’t change the transmitted EDID.
Update with EDID injector dongle (without 3D):
I tested a hardware EDID injector ( xieoery HDMI EDID Emulator Dual-Channel 4K HDR Dummy Plug, 3840 x 2160 @ 60Hz Standard, Headless Ghost Display Adapter for GPU Server, Remote Access, KVM & 120Hz Support 120Hz High-Refresh: Amazon.de: Electronics & Photo )
The output now accepts 4k60 with HDR fine, with the dongle plugged in between HDMI port and HDMI cable to the beamer. The EDID dongle doesn’t advertise 3D in its EDID, so this really seems to be the culprit here.
Besides that, I still can’t use the beamer 4k60 as this resolution somehow gives no output signal at the dongles female end. So this is no solution for me yet. Still debugging.
