I believe I’ve found a bug with nvcc that kills the ‘stat’ functionality on OS X (but not Linux).
I’m using the following test snippet:
#include <sys/stat.h>
#include <stdio.h>
long int file_size(const char *path) {
struct stat file_status;
if(stat(path, &file_status) != 0){
printf("Unable to stat %s\n", path);
return -1;
printf("File size of %s is %d\n", path, (int)file_status.st_size);
return file_status.st_size;
int main() {
char filename[] = "foo";
printf("Size: %d\n", (int)file_size(filename));
The following happens:
$ gcc -o test test.c; ./test
File size of foo is 10
$ nvcc -o test test.c; ./test
File size of foo is 0
Foo is, of course, 10 bytes.
$ nvcc --version
Copyright (c) 2005-2010 NVIDIA Corporation
Built on Thu_Jun_17_16:11:55_PDT_2010
Cuda compilation tools, release 3.1, V0.2.1221
Ideas? Suggestions?
//EDIT: Realized I was using 3.0, updated to 3.1, same issue.
Just found the same error; OS X Cuda 3.1. Going to have to do a workaround for the file info.
Still fails on NVCC 4.0.2. The problem appears to be that ‘long’ is 4 bytes under nvcc, and 8 bytes under Apple’s gcc. As a result, nvcc thinks the struct timespec parts of struct stat are 8 bytes, not 16, and the st_size field is found at the wrong place. NVCC sees struct stat as 112 bytes, when 144 is actually correct. The failure appear’s to be caused by Apple: their <sys/_struct.h> uses long and off_t for the fields in struct timespec, rather than exact types such as int64_t. Try the following program (test1.c) under gcc and nvcc:
#include <stdio.h>
#include <stdlib.h>
int main() {
printf(“char: %ld\n”, sizeof(char));
printf(“short: %ld\n”, sizeof(short));
printf(“int: %ld\n”, sizeof(int));
printf(“long: %ld\n”, sizeof(long));
printf(“long long: %ld\n\n”, sizeof(long long));
printf(“float: %ld\n”, sizeof(float));
printf(“double: %ld\n”, sizeof(double));
printf(“long double: %ld\n\n”, sizeof(long double));
printf(“timespec: %ld\n”, sizeof(struct timespec));
printf(“stat: %ld\n”, sizeof(struct stat));
printf(“stat64: %ld\n\n”, sizeof(struct stat64));
printf(“off_t: %ld\n\n”, sizeof(off_t));
struct stat s;
lstat(“test1.c”, &s);
printf(“size: %ld\n”, s.st_size);
return EXIT_SUCCESS;
