[BUG] nvidia-container-runtime-csv-mode cannot create sym link of dir
Required Info:
  • Software Version
    DRIVE OS 6.0.6
  • Target OS
    Linux
  • SDK Manager Version
    1.9.2.10884
  • Host Machine Version
    native Ubuntu Linux 20.04 Host installed with DRIVE OS DOCKER Containers
Describe the bug
in target-docker-container in drive-orinkit, nvidia-container-runtime-csv-mode cannot create sym link of dir.
To Reproduce
in drive-orin-kit, start container using the following scripts and csv files.
with -e NVIDIA_REQUIRE_JETPACK="csv-mounts=all" to allow all csv files take effect. see Add `nvidia-container-runtime.modes.csv.allowed-files` config option (#11) · Issues · nvidia / container-toolkit / container-toolkit · GitLab
nvidia@tegra-ubuntu:~/zhensheng/orin_ws/nv_driveworks_demo/target/docker/scripts$ ls
gw_base.sh  my.bashrc  orin_adduser.sh  orin_postbuild.sh  sdk_adduser.sh  sdk_postbuild.sh  target_adduser.sh  target_postbuild.sh
the driveworks folder is mapped to the container. using csv files.
sym, /usr/local/driveworks
dir, /usr/local/driveworks-5.10
# in host
nvidia@tegra-ubuntu:~/zhensheng/orin_ws/nv_driveworks_demo/target/docker/scripts$ ll -d /usr/local/driveworks*
lrwxrwxrwx. 1 root root   26 Jan 29 07:52 /usr/local/driveworks -> /usr/local/driveworks-5.10/
drwxr-xr-x. 7 root root 4096 Jan 29 07:49 /usr/local/driveworks-5.10/
# in container
nvidia@in_orin_docker:/usr/local$ ll -d /usr/local/driveworks*
Expected behavior
we can see the sym link of driveworks folder in container.
Actual behavior
cannot see this.
Additional context
It’s actually an issue of nvidia-container-runtime.
Dear @lizhensheng,
Yes. You are right. How about create symlink for needed libs on target or mounting the host folder which has aarch64 libs and update paths accordingly to pick up those libs instead of libs on target. Does that work as work around?
Yes, there is a lot of ways that work as workaround
if you don’t treat it as a bug.
Thanks @SivaRamaKrishnaNV ,
Then there is a hard problem, could you help with this topic ? [BUG] target-docker-container running cuda-samples require unintended extra permission - DRIVE AGX Orin / DRIVE AGX Orin General - NVIDIA Developer Forums
