Should be easy to reproduce following this sample code.
// Created by hunglx on 17/10/2022.
#include <gtest/gtest.h>
#include <gst/gst.h>
#include <nvdsmeta.h>
#include <gstnvdsmeta.h>
static GstPadProbeReturn
mux_src_probe(GstPad *pad, GstPadProbeInfo *info, gpointer user_data) {
GstBuffer *gst_buffer = static_cast<GstBuffer *>(info->data);
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(gst_buffer);
for (NvDsMetaList *l_frame = batch_meta->frame_meta_list; l_frame != nullptr; l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = static_cast<NvDsFrameMeta *>(l_frame->data);
NvDsDisplayMeta *display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
display_meta->num_arrows = 0;
NvOSD_ArrowParams &arrow = display_meta->arrow_params[display_meta->num_arrows];
display_meta->num_arrows++;
arrow.x1 = 200;
arrow.y1 = 200;
arrow.x2 = 300;
arrow.y2 = 300;
arrow.arrow_width = 4;
arrow.arrow_head = END_HEAD;
arrow.arrow_color = NvOSD_ColorParams{.red=0.0, .green=1.0, .blue=0.0, .alpha=1.0};
nvds_add_display_meta_to_frame(frame_meta, display_meta);
return GST_PAD_PROBE_OK;
tiler_src_probe(GstPad *pad, GstPadProbeInfo *info, gpointer user_data) {
for (NvDsMetaList *l_display = frame_meta->display_meta_list; l_display != nullptr; l_display = l_display->next) {
NvDsDisplayMeta *display_meta = static_cast<NvDsDisplayMeta *>(l_display->data);
NvOSD_ArrowParams &arrow_params = display_meta->arrow_params[0];
printf("arrow: x1: %d y1: %d x2: %d y2: %d\n", arrow_params.x1, arrow_params.y1, arrow_params.x2, arrow_params.y2);
int main() {
gst_init(nullptr, nullptr);
setenv("USE_NEW_NVSTREAMMUX", "yes", 1);
std::string pipeline_str =
"videotestsrc ! nvvideoconvert ! video/x-raw(memory:NVMM),width=1280,height=720 ! mux.sink_0 "
"videotestsrc ! nvvideoconvert ! video/x-raw(memory:NVMM),width=1280,height=720 ! mux.sink_1 "
"videotestsrc ! nvvideoconvert ! video/x-raw(memory:NVMM),width=1280,height=720 ! mux.sink_2 "
"videotestsrc ! nvvideoconvert ! video/x-raw(memory:NVMM),width=1280,height=720 ! mux.sink_3 "
"nvstreammux name=mux batch-size=1 ! nvmultistreamtiler name=tiler ! nvvideoconvert ! nvdsosd ! "
#ifdef __aarch64__
"nvegltransform ! "
#else
"identity ! "
#endif
"nveglglessink";
GstElement *pipeline = gst_parse_launch(pipeline_str.c_str(), nullptr);
GMainLoop *main_loop = g_main_loop_new(nullptr, false);
GstBus *bus = gst_element_get_bus(pipeline);
GstElement *streammux = gst_bin_get_by_name(GST_BIN(pipeline), "mux");
GstPad *mux_src_pad = gst_element_get_static_pad(streammux, "src");
gst_pad_add_probe(mux_src_pad, GST_PAD_PROBE_TYPE_BUFFER, mux_src_probe, nullptr, nullptr);
gst_object_unref(mux_src_pad);
GstElement *tiler = gst_bin_get_by_name(GST_BIN(pipeline), "tiler");
GstPad *tiler_src_pad = gst_element_get_static_pad(tiler, "src");
gst_pad_add_probe(tiler_src_pad, GST_PAD_PROBE_TYPE_BUFFER, tiler_src_probe, nullptr, nullptr);
gst_object_unref(tiler_src_pad);
auto callback_bus_message = +[] (GstBus *bus, GstMessage *msg, gpointer user_data) {
GMainLoop *loop = static_cast<GMainLoop *>(user_data);
switch (GST_MESSAGE_TYPE(msg)) {
case GST_MESSAGE_EOS: {
g_main_loop_quit(loop);
break;
default:
break;
return TRUE;
gst_bus_add_watch(bus, reinterpret_cast<GstBusFunc>(callback_bus_message), main_loop);
gst_object_unref(bus);
gst_element_set_state(pipeline, GST_STATE_PLAYING);
g_main_loop_run(main_loop);
gst_element_set_state(pipeline, GST_STATE_NULL);
gst_object_unref(pipeline);
g_main_loop_unref(main_loop);
We have 4 sources feed into nvstreammux.
In nvstreammux src pad, I attach a probe function to add a arrow-display meta with position: 200, 200, 300, 300
In nvmultistreamtiler src pad I attach a probe function to print rescaled-arrow-display meta. You can easily see that the arrow meta is rescaled properly on x86 platform
and on Jetson platform, it’s not rescaled properly
