I’m noticing that if the Force Fields extension is loaded, then the Physics - Start as Sleep property has no effect for Bodies.
Indeed, I was able to repro the issue. I have created internal Jira ticket to resolve the issue we should fix it asap. Thanks for reporting!
Related topics
Topic | Replies | Views | Activity | |
AddForce with autowake set to false makes bodies drift | 0 | 607 | May 24, 2024 | |
Problem when enable the “PHYSX FORCEFIELDS” extension | 2 | 99 | June 24, 2024 | |
Can't change direction of planar force field | 3 | 528 | March 30, 2023 | |
Is force field able to affect particle/deformable body? | 7 | 636 | May 13, 2024 | |
Async sim + Forcefields results in cascade of errors | 1 | 361 | August 2, 2023 | |
How to pause the game with PhysX | 1 | 769 | April 4, 2019 | |
Is the Force Field source code available? | 2 | 236 | April 19, 2024 | |
Starts as asleep and time to wake | 11 | 829 | March 25, 2022 | |
Height filed doesn't put actors to sleep | 0 | 658 | August 4, 2015 | |
`rigid_body_physics` and `gravity` does not work | 3 | 561 | April 13, 2023 |
