The following code fails with “nvcc --device-emulation -c test.cu”
test.cu:14: error: ‘_ZZN8MyStruct5helloEvEs’ was not declared in this scope
#include <stdio.h>
#include <cuda.h>
struct MyStruct {
__device__ void hello();
__device__ void MyStruct::hello() {
printf("hello world.\n");
__global__ void device_main() {
MyStruct s;
s.hello();
int cuda_main() {
device_main<<< 1, 1 >>>();
return 0;
changing the second block to the following fixes the problem
__device__ void globalscope_hello() {
globalscope_hello();
nvcc “release 2.0, V0.2.1221”, “built on Thu_Jun_19_04:48:21_PDT_2008”
cheers,
Nicholas
Actually, it seems worse than that; it seems to fail with any pointer if it’s called from a device class function.
__device__ void globalscope_hello(const char *str) {
printf("hello world '%s'.\n", str);
globalscope_hello("something");
getting rid of the class works
__device__ __host__ void globalscope_hello(const char *str) {
globalscope_hello("asdfq");
any workarounds would be much appreciated. I’d prefer to be able to use classes and debug… unfortunate this doesn’t seem to work immediately with cuda 2.0.
thanks,
Nicholas
tmurray
October 19, 2008, 6:06am
#3
C++ is unsupported–some features may work sporadically, as you’ve seen, but things like classes and operator overloading will almost certainly break from version to version.
