[bug][ptxas][nvrtc] ptxas/NVRTC 13 segfault while compiling certain kernels
A CUDA compiler bug causes ptxas/NVRTC to segfault while compiling certain kernels with `-O3 --register-usage-level=10`.
The ptxas/NVRTC crash reproduces on both Linux ARM64 and x86_64 with CUDA 13.3 and 13.4.
Save the PTX below as `repro.ptx`, then run:
ptxas -arch=sm_121a -O3 --register-usage-level=10 repro.ptx -o repro.cubin
.version 9.3
.target sm_121a
.address_size 64
.extern .shared .align 16 .b8 shared_memory[];
.visible .entry repro()
.maxntid 384
.minnctapersm 1
    .reg .pred  %p<40>;
    .reg .b16   %rs<8>;
    .reg .b32   %r<725>;
    .reg .b64   %rd<199>;
    and.b32     %r174, %r173, 7;
    and.b32     %r176, %r58, 24;
    or.b32  %r19, %r174, %r176;
    or.b32  %r179, %r178, %r174;
    cvt.u64.u32     %rd7, %r179;
    or.b64  %rd10, %rd7, 240;
    mul.wide.u32    %rd60, %r19, 4;
    shl.b64     %rd188, %rd10, 2;
$L__BB0_40:
    mov.b32     %r670, %r631;
$L__BB0_43:
    @%p36 bra   $L__BB0_49;
    { cvt.rn.bf16x2.f32 %r496, %r667, %r668;}
    st.b32  [%rd132+62464], %r496;
    { cvt.rn.bf16x2.f32 %r505, %r649, %r650;}
    st.b32  [%rd148+61440], %r505;
    @%p39 bra   $L__BB0_40;
    ret;
$L__BB0_49:
    ldmatrix.sync.aligned.m8n8.x2.shared.b16 {%r566,%r567}, [%r527];
    ldmatrix.sync.aligned.m8n8.x4.shared.b16 {%r552,%r553,%r554,%r555}, [%r530];
    add.s64     %rd173, %rd172, %rd60;
    ld.b32  %r556, [%rd173+27072];
    ldmatrix.sync.aligned.m8n8.x2.shared.b16 {%r702,%r701}, [%r533];
    ldmatrix.sync.aligned.m8n8.x4.shared.b16 {%r722,%r721,%r720,%r719}, [%r535];
    mma.sync.aligned.kind::mxf4nvf4.block_scale.scale_vec::4X.m16n8k64.row.col.f32.e2m1.e2m1.f32.ue4m3 {%r650, %r649, %r648, %r647}, {%r552, %r553, %r554, %r555}, {%r566, %r567}, {%r650, %r649, %r648, %r647}, {%r556}, {%rs6, %rs6}, {%r547}, {%rs6, %rs7};
    ldmatrix.sync.aligned.m8n8.x2.shared.b16 {%r602,%r603}, [%r569];
    ldmatrix.sync.aligned.m8n8.x4.shared.b16 {%r597,%r598,%r599,%r600}, [%r574];
    add.s64     %rd189, %rd186, %rd188;
    ld.b32  %r601, [%rd189+26880];
    mma.sync.aligned.kind::mxf4nvf4.block_scale.scale_vec::4X.m16n8k64.row.col.f32.e2m1.e2m1.f32.ue4m3 {%r670, %r669, %r668, %r667}, {%r722, %r721, %r720, %r719}, {%r702, %r701}, {%r670, %r669, %r668, %r667}, {%r698}, {%rs6, %rs6}, {%r723}, {%rs6, %rs6};
    fence.acq_rel.cta;
    mma.sync.aligned.kind::mxf4nvf4.block_scale.scale_vec::4X.m16n8k64.row.col.f32.e2m1.e2m1.f32.ue4m3 {%r634, %r633, %r632, %r631}, {%r597, %r598, %r599, %r600}, {%r602, %r603}, {%r634, %r633, %r632, %r631}, {%r601}, {%rs6, %rs6}, {%r583}, {%rs6, %rs7};
    bra.uni     $L__BB0_43;
