I am running into a compilation error with CUDA 2.1 beta on Ubuntu 8.04 using g++ 4.2.4. The following is a minimal test case (yes, just one include, no other code):
#include <fstream>
When I try to compile this, I get:
nvcc -c testcase.cu
/usr/include/c++/4.2/bits/ios_base.h:408: error: declaration of ‘typedef class std::streampos std::ios_base::streampos’
/usr/include/c++/4.2/bits/postypes.h:211: error: changes meaning of ‘streampos’ from ‘typedef class std::fpos<__mbstate_t> std::streampos’
/usr/include/c++/4.2/bits/ios_base.h:409: error: declaration of ‘typedef std::streamoff std::ios_base::streamoff’
/usr/include/c++/4.2/bits/postypes.h:72: error: changes meaning of ‘streamoff’ from ‘typedef int64_t std::streamoff’
Should anyone else run into this, here is a workaround that works for me (using 2.1 beta). I modeled this after CUDA 2.0 but of course I cannot guarantee it won’t break something in 2.1…
--- math_functions.h.orig 2008-12-18 14:36:21.000000000 +0000
+++ math_functions.h 2008-12-18 14:39:41.000000000 +0000
@@ -471,6 +471,7 @@
template<typename T> extern __host__ __device__ T __cmath_power(T, unsigned int);
+using namespace std;
using std::abs;
using std::fabs;
using std::ceil;
Cool, two different workarounds then exist. I personally prefer to add a hack where the bug is (i.e. in CUDA, not in my source) but changing the source may be less intrusive in some cases I guess.
