IDE: Visual Studio 2010 SP1
OS: Windows 8, x64
GPU: nVidia GeForce GT 650m
When project (any project) is located at directory, path of which contains russian symbols AND “Compute Capability” is set to 2.0 or greater, nvcc.exe crashes.
Error 1 error : Ptx assembly aborted due to errors D:\Тест\vectorAdd\ptxas vectorAdd
Error 2 can’t write here (site refuses)
When path is english OR compute_10,code="sm_10,compute_10" - all right
If this issue occurs with the toolchain from CUDA 5.0 or CUDA 5.5 RC, please file a bug using the bug reporting form linked from the registered developer website. Thank you for your help.
If you are using an older version of CUDA, I would suggest trying a recent version of CUDA as the issue may have already been addressed.
(1) Login at https://developer.nvidia.com/user/login
(2) Click green link “CUDA/GPU Computing Registered Developer Program”
(3) Under heading “Reporting An Issue” click green link “The Submit a Bug Form”
If you are not a registered developer yet: the application process is straightforward and approval typically happens within one business day.
