Description
I am reporting a reproducible Jetson-IO issue on a Jetson Orin Nano Super Developer Kit where Jetson-IO reports a duplicate DT overlay when two DTBO files in /boot have the same overlay-name metadata.
Platform
- Board: NVIDIA Jetson Orin Nano Super Developer Kit
- P3768 carrier / P3767 module
- Jetson Linux / L4T: R36.5.2
- Ubuntu: 22.04.5 LTS
- 40-pin header: Jetson 40pin Header
Problem
I have two DTBO files in /boot:
jetson-io-hdr40-user-custom.dtbojetson-uart-fix.dtbo
Both contain the same Jetson-IO metadata:
overlay-name = "User Custom [2026-08-15-140508]";
jetson-header-name = "Jetson 40pin Header";
When both files are present in /boot, Jetson-IO reports a duplicate overlay and cannot be used normally.
The second DTBO is not intended to be another Jetson-IO hardware configuration. It is an independently created overlay used for UART configuration.
Reproduction
With both DTBOs present in /boot, running Jetson-IO results in a duplicate-overlay error.
I inspected the Jetson-IO Python implementation and found that board.py scans DTBOs and uses the root overlay-name when building the available hardware configurations. It raises an error when the same overlay name is encountered more than once.
If I temporarily move the unrelated jetson-uart-fix.dtbo out of /boot, Jetson-IO runs normally and the generated HDR40 configuration is detected.
Restoring the DTBO reproduces the problem.
Expected behavior
I would expect Jetson-IO to either:
- Ignore DTBOs that are not Jetson-IO hardware configuration overlays, or
- Use a more specific mechanism to determine whether a DTBO belongs to Jetson-IO before treating its
overlay-nameas a Jetson-IO configuration identifier.
An unrelated DTBO carrying Jetson-IO metadata should not prevent Jetson-IO from discovering the actual Jetson-IO configuration.
Relevant Jetson-IO source
The relevant logic appears to be in:
/opt/nvidia/jetson-io/Jetson/board.py
The _board_find_overlays() path scans available DTBOs and checks the root overlay-name. Duplicate names result in:
RuntimeError("Multiple DT overlays for '%s' found!" ...)
I have included the relevant source code and reproduction details in the attached report.
Workaround
The current workaround is to keep the unrelated DTBO outside /boot while using Jetson-IO.
This is not ideal because the DTBO is otherwise required by the system’s boot configuration.
Additional information
I also created a separate merged DTB to verify that the underlying HDR40 pinmux configuration itself can be applied correctly without relying on Jetson-IO. The resulting DTB successfully boots on the target.
This report is specifically about the Jetson-IO DTBO discovery / duplicate-overlay behavior. I am not attributing unrelated I²C peripheral issues to this Jetson-IO behavior.
Questions
Could NVIDIA please clarify:
- Is
overlay-nameintentionally treated as a globally unique identifier by Jetson-IO? - Is there a documented requirement that every DTBO placed in
/bootmust have a uniqueoverlay-name? - Should unrelated DTBOs be given special metadata so Jetson-IO ignores them?
- Is there a recommended way to create an independent DTBO without it being interpreted as a Jetson-IO hardware configuration?
- Is this behavior expected in Jetson Linux R36.5.2, or is it considered a Jetson-IO bug/design limitation?
I have attached the detailed report and NVIDIA diagnostic log.
NVIDIA_JetsonIO_Issue_Report_Package (1).zip (74.6 KB)
NVIDIA_JetsonIO_Issue_Report_with_code_blocks.docx (38.1 KB)
