Bug Report - NVIDIA NVKMS Memory Allocation Error
General information
Component: nvidia_drm (NVIDIA DRM driver)
Type: Memory allocation error
Severity: High (causes graphics freezes as soon as an application is in full screen)
I tried a fresh install but it’s the same.
Same problem with 570 driver
Error Description
[drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
Observed Symptoms
dmesg | grep -i nvidia
[    6.693192] nvidia: loading out-of-tree module taints kernel.
[    6.693204] nvidia: module license 'NVIDIA' taints kernel.
[    6.693209] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    6.693210] nvidia: module license taints kernel.
[    7.545636] nvidia-nvlink: Nvlink Core is being initialized, major device number 239
[    7.555097] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[    7.673523] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  575.64.05  Fri Jul 18 16:01:21 UTC 2025
[    7.777764] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  575.64.05  Fri Jul 18 15:45:08 UTC 2025
[    7.788824] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    7.826968] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/0000:01:00.1/sound/card2/input5
[    7.827048] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/0000:01:00.1/sound/card2/input6
[    7.827143] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/0000:01:00.1/sound/card2/input7
[    7.827237] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.0/0000:01:00.1/sound/card2/input8
[    8.336267] [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 1
[    8.401258] nvidia 0000:01:00.0: vgaarb: deactivate vga console
[    8.409790] fbcon: nvidia-drmdrmfb (fb0) is primary device
[    8.409801] nvidia 0000:01:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
[    8.467639] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[24107.940905] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
[24107.940969] [drm:nv_drm_gem_alloc_nvkms_memory_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate NVKMS memory for GEM object
Observed Symptoms
    • Rendering issues : black screen
System Context
6.12.64-1-MANJARO
lspci | grep -i vga
01:00.0 VGA compatible controller: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] (rev a1)
Sat Jan 24 20:01:13 2026
| NVIDIA-SMI 575.64.05              Driver Version: 575.64.05      CUDA Version: 12.9     |
|   0  NVIDIA GeForce GTX 1050 Ti     Off |   00000000:01:00.0  On |                  N/A |
| 20%   41C    P5            N/A  /   75W |    1191MiB /   4096MiB |      3%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI              PID   Type   Process name                        GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A             670      G   /usr/lib/Xorg                            20MiB |
|    0   N/A  N/A             807      G   /usr/bin/ksecretd                         1MiB |
|    0   N/A  N/A             844      G   /usr/bin/kwin_wayland                   208MiB |
|    0   N/A  N/A             931      G   /usr/bin/Xwayland                       117MiB |
|    0   N/A  N/A             962      G   /usr/bin/ksmserver                        1MiB |
|    0   N/A  N/A             965      G   /usr/bin/kded6                            1MiB |
|    0   N/A  N/A             983    C+G   /usr/bin/plasmashell                    278MiB |
|    0   N/A  N/A            1053      G   /usr/bin/kaccess                          1MiB |
|    0   N/A  N/A            1054      G   …it-kde-authentication-agent-1          1MiB |
|    0   N/A  N/A            1152      G   /usr/bin/kdeconnectd                      1MiB |
|    0   N/A  N/A            1228      G   /usr/bin/pamac-tray-plasma                1MiB |
|    0   N/A  N/A            1235      G   /usr/lib/firefox/firefox                324MiB |
|    0   N/A  N/A            1273      G   /usr/lib/xdg-desktop-portal-kde           1MiB |
|    0   N/A  N/A            2526      G   /usr/bin/krunner                          9MiB |
|    0   N/A  N/A            2612      G   /usr/lib/baloorunner                      1MiB |
|    0   N/A  N/A            2855      G   …share/Steam/ubuntu12_32/steam          2MiB |
|    0   N/A  N/A            3038      G   ./steamwebhelper                         27MiB |
|    0   N/A  N/A            3077    C+G   …am/ubuntu12_64/steamwebhelper          4MiB |
|    0   N/A  N/A           36630      G   /usr/bin/dolphin                          1MiB |
|    0   N/A  N/A           66902      G   /usr/bin/konsole                          1MiB |
|    0   N/A  N/A           68756    C+G   /usr/bin/amarok                         103MiB |
I’m experiencing the same (or at least very similar) on Arch, EndeavourOS.
The only difference is that this appears to only happen when the PC tries to sleep whilst being locked.
I get a black screen with the line OP mentioned and preceding that line are the following two:
Freezing user space processes failed after 20.003 seconds (1 tasks refusing to freeze, wq_busy=0)
Freesing user space processes failed after 20.006 seconds (1 tasks refusing to freeze, wq_busy=0)
By calling for a TTY (Ctrl + Shift + F3) and then the UI I’m able to recover back to the login screen, however this isn’t ideal for my monitors displaying this text the entire time.
I’m on 590.48.01.
another round today :
black screen when apps want display in full screen, wait 5 seconds, display is ok, wait one minute, and …. black screen and another turn !
the same thing when i want to capture the screen.
I launch a game and …. black screen persist !
dmesg :
[   11.604558] r8169 0000:04:00.0 enp4s0: Link is Up - 1Gbps/Full - flow control rx/tx
[  709.796761] perf: interrupt took too long (2508 > 2500), lowering kernel.perf_event_max_sample_rate to 79000
[ 1233.299366] perf: interrupt took too long (3145 > 3135), lowering kernel.perf_event_max_sample_rate to 63000
[ 2919.009905] perf: interrupt took too long (3940 > 3931), lowering kernel.perf_event_max_sample_rate to 50000
[ 6221.275195] perf: interrupt took too long (5046 > 4925), lowering kernel.perf_event_max_sample_rate to 39000
[ 8657.649162] r8169 0000:04:00.0 enp4s0: Link is Down
[ 8658.637122] [drm:__nv_drm_semsurf_wait_fence_work_cb [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to register auto-value-update on pre-wait value for sync FD semaphore surface
[ 8658.643401] PM: suspend entry (deep)
[ 8659.506849] [drm:__nv_drm_semsurf_wait_fence_work_cb [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to register auto-value-update on pre-wait value for sync FD semaphore surface
[ 8660.741806] Filesystems sync: 2.098 seconds
[ 8660.742272] Freezing user space processes
[ 8662.802419] Freezing user space processes completed (elapsed 2.060 seconds)
[ 8662.802429] OOM killer disabled.
[ 8662.802432] Freezing remaining freezable tasks
[ 8662.804055] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[ 8662.804086] printk: Suspending console(s) (use no_console_suspend to debug)
[ 8662.813609] serial 00:05: disabled
[ 8662.813939] sd 2:0:0:0: [sdc] Synchronizing SCSI cache
Just an update on this.
I’m still on driver version 590.48.01, but I’ve not seen this issue pop up in a good few weeks now, especially in the situation that I previously described it; when the PC tries to sleep.
I wonder if there was a bug in another utility/process that manifested as NVIDIA being unable to cope, but fingers crossed it’s solved.
