Subject: [BUG] RTX 5050 Mobile Dynamic Boost stuck at VBIOS 35W — NPCF SSDT returns zeroed power budget
Platform: NVIDIA Developer Forums (forums.developer.nvidia.com/c/linux-linux/800)
Summary
On the Lenovo LOQ Essential 15IRX11 (83SC) with RTX 5050 (GB207M, 10DE:2D98), Dynamic Boost never activates. The GPU stays at the VBIOS default 35W instead of boosting to 65W (50W TGP + 15W PPAB). The root cause is the stock BIOS NPCF SSDT returns zeroed power budget fields in all NVPCF DSM subfunctions — the driver constructs the PMO successfully (func 0x00 bit 0 IS set), but all downstream budget data is zeroed, so Dynamic Boost offsets compute as 0W and the GPU never leaves VBIOS defaults.
This is confirmed on Windows 11 with stock BIOS — same 45W flatline. The bug is in the ACPI tables, not the driver. An SSDT override with corrected NPCF power budget values (TGPA=0x0208, TPPA=0x0438, MAGA=0x03C0) fully resolves the issue, restoring 65W sustained boost.
Cross-referencing GitHub issue #1162 — same NPCF binding issue affects other Blackwell laptops with identical zeroed-budget behavior. This appears to be a widespread BIOS firmware problem across Lenovo’s 2026 lineup.
Stock BIOS Evidence
func 0x02 return (49 bytes, all budget fields zeroed):
TGPA (offset 0x05): 0x0000 = 0W ← should be 65W (0x0208)
TGPD (offset 0x07): 0x0000 = 0W
TPPA (offset 0x19): 0x0000 = 0W ← should be 135W (0x0438)
MAGA (offset 0x1D): 0x0000 = 0W ← should be 120W (0x03C0)
func 0x00 returns Buffer(4){0xBF,0x06,0x00,0x00} — bit 0 IS set, so PMO constructs. But all downstream func 0x02 fields are zeroed.
nvidia-smi Output (Stock BIOS)
Current Power Limit: 35.00W (VBIOS default — never boosts)
Default Power Limit: 35.00W
Max Power Limit: 65.00W (hardware maximum, never reached)
Requested Power Limit: N/A (nvidia-powerd never requests boost)
nvidia-powerd runs, DBus connected, zero activity logs. Falls back to “SBIOS support not found for NVPCF GET_SUPPORTED” → default TPP.
dmesg errors:
NVRM: GPU0 PlatformRequestHandler failed to get target temp from SBIOS @ platform_request_handler_ctrl.c:2174
NVRM: GPU0 PlatformRequestHandler failed to get platform power mode from SBIOS @ platform_request_handler_ctrl.c:2117
The Fix
SSDT override via CONFIG_ACPI_TABLE_UPGRADE initrd mechanism. Embed Device(NPCF) at Scope(_SB) in the DSDT with corrected power budget values:
TGPA = 0x0208 // 520 × 125mW = 65W (TGP + CTGP + PPAB)
TPPA = 0x0438 // 1080 × 125mW = 135W (total platform power budget)
MAGA = 0x03C0 // 960 × 125mW = 120W (max AC GPU allocation)
GPS pipeline also patched:
- Removed GPSS guard from _DSM dispatcher (driver probes GPS before _INI sets GPSS=1)
- Added Case(0x24) for GETPPL — returns {V1, PL1=45W, PL2=65W}
- Enlarged GPSP buffer from 0x28 to 0x2C bytes, set PPMD status bit
Key driver paths:
- nv-acpi.c:785-793 — hardcodes pathname “_SB.NPCF._DSM”
- client_resource.c:2942/2992/3121 — GET_SUPPORTED bit 0 check, func 0x02 header validation
- platform_request_handler_ctrl.c:2174/2117 — PSHAREPARAMS PPMD sensor failures
After Fix Results
Current Power Limit: 65.00W (Dynamic Boost active)
Synthetic load: 65W sustained (cuda-matmul 30s)
Genshin Impact avg: 53.1W (with CPU -75mV undervolt)
GPS GETPPL: {V1, PL1=45W, PL2=65W}
GPS PSHAREPARAMS: 44-byte buffer with PPMD=7 sensor
Repository
Full patched SSDT source, scripts, and power measurement data:
Questions for NVIDIA Engineers
When func 0x02 returns all-zero budget fields, the driver silently falls back to VBIOS defaults with no warning. A pr_warn when ctgpOffsetmW == 0 && maxOutputOffsetmW == 0 (after func 0x00 reports support) would help users diagnose this class of firmware bug. Is this intentional?
Should the driver validate func 0x02 budget values? Currently client_resource.c validates header structure (sizes, version) but not whether TGPA/TPPA/MAGA are non-zero when bit 0 of func 0x00 indicates support.
The PlatformRequestHandler NV_ERR_INVALID_DATA errors at lines 2174/2117 fire when PSHAREPARAMS doesn’t populate the PPMD field. Is this expected for laptops without platform power mode support, or should the driver handle missing PPMD gracefully?
System: Lenovo LOQ Essential 15IRX11 83SC | BIOS SECN22WW | RTX 5050 GB207M | Kernel 7.2.3-1-cachyos | nvidia-open 610.57.04
nvidia-bug-report.log.gz (2.0 MB)
