[BUG] RTX 5070 disappears from the PCIe bus
System
  • GPU: ASUS NVIDIA GeForce RTX 5070 (GB205)
  • Motherboard: ASUS ROG STRIX X470-F GAMING
  • CPU: AMD Ryzen 7 2700X
  • BIOS: 6232 (2024-09-29)
  • OS: Arch Linux
  • Kernel: 7.1.4-arch1-1
  • NVIDIA driver: 610.43.03
  • Kernel module: NVIDIA Open Kernel Module (nvidia-open)
  • Desktop: KDE Plasma / Wayland
  • GPU connection: Directly installed in the motherboard’s PCIe x16 slot; no riser cable
  • PCIe link: PCIe 3.0 x16 (8 GT/s x16)
Problem
I am experiencing recurring system crashes where the RTX 5070 disappears from the PCIe bus.
The most recent occurrence happened during a normal Arch Linux system upgrade (pacman -Syu), but this is not limited to package upgrades; I have experienced similar crashes at other times as well.
After rebooting from the crash, the previous boot’s kernel journal shows a large number of PCIe AER errors involving the RTX 5070 immediately before the NVIDIA driver reports Xid 79.
Initially the errors are primarily:
pcieport 0000:00:03.1: AER: Correctable error message received from 0000:09:00.0
nvidia 0000:09:00.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
nvidia 0000:09:00.0: device [10de:2f04] error status/mask=00000001/0000e000
nvidia 0000:09:00.0: [ 0] RxErr (First)
The errors then escalate to BadTLP and PCIe data-link timeouts:
nvidia 0000:09:00.0: device [10de:2f04] error status/mask=00000041/0000e000
nvidia 0000:09:00.0: [ 6] BadTLP
pcieport 0000:00:03.1: PCIe Bus Error: severity=Correctable, type=Data Link Layer, (Transmitter ID)
pcieport 0000:00:03.1: device [1022:1453] error status/mask=00001000/00006000
pcieport 0000:00:03.1: [12] Timeout
This is followed almost immediately by:
NVRM: GPU at PCI:0000:09:00: GPU-40ffbe49-76f5-fdb2-b42e-45422378faff
NVRM: Xid (PCI:0000:09:00): 79, pid=1177, name=kwin_wayland, GPU has fallen off the bus.
NVRM: GPU 0000:09:00.0: GPU has fallen off the bus.
NVRM: krcRcAndNotifyAllChannels_IMPL: RC all channels for critical error 79.
NVRM: _threadNodeCheckTimeout: API_GPU_ATTACHED_SANITY_CHECK failed!
The machine becomes unusable and requires a reboot.
PCIe information
The GPU reports:
LnkCap: Port #0, Speed 32GT/s, Width x16
LnkSta: Speed 8GT/s (downgraded), Width x16
LnkCap2: Supported Link Speeds: 2.5-32GT/s
LnkCtl2: Target Link Speed: 32GT/s
The AMD root port (00:03.1) reports:
LnkCap: Port #0, Speed 8GT/s, Width x16
LnkSta: Speed 8GT/s, Width x16
LnkCap2: Supported Link Speeds: 2.5-8GT/s
LnkCtl2: Target Link Speed: 8GT/s
Therefore, the PCIe 3.0 x16 negotiated link appears correct for this X470/Ryzen 2700X platform.
After rebooting, AER status on both the GPU and root port is clean:
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- ...
The PCIe errors appear during/around the failure rather than continuously.
NVIDIA driver/package information
I originally had:
nvidia-open-dkms 610.43.03
nvidia-utils 610.43.03
lib32-nvidia-utils 610.43.03
I use only Arch’s standard linux kernel, so I subsequently changed from nvidia-open-dkms to the precompiled nvidia-open package.
The currently loaded module is the open NVIDIA kernel module:
version: 610.43.03
license: Dual MIT/GPL
The problem has occurred with the NVIDIA open kernel module.
Motherboard firmware
Current BIOS:
Vendor: American Megatrends Inc.
Version: 6232
Release Date: 09/29/2024
ASUS has subsequently released BIOS 6254 beta with the description “Improve system compatibility”, but I have not installed the beta BIOS yet.
I have also found reports from other ASUS ROG STRIX X470-F GAMING users experiencing freezes/problems with RTX 5070/5070 Ti GPUs, so I am interested in whether there is a known compatibility issue between Blackwell GPUs and older AMD PCIe 3.0 platforms.
Bug report
I ran:
sudo nvidia-bug-report.sh
It completed successfully and detected:
Detected driver type: Running RM Driver on GPUs
complete.
I will attach the generated:
nvidia-bug-report.log.gz
Some optional utilities (lsusb, ibstat, acpidump, mst, and nvlsm-bug-report.sh) were unavailable, but the main NVIDIA bug-report collection completed.
Is this a known issue with RTX 50-series/Blackwell GPUs on older AMD PCIe 3.0 platforms, or does the RxErr -> BadTLP -> PCIe timeout -> Xid 79 sequence suggest a hardware/firmware PCIe compatibility problem?
nvidia-bug-report.log.gz (537.1 KB)
GPU falling off the bus is pretty much always a hardware issue.
Either your GPU, PSU or motherboard could be damaged.
I had the same (general) issue with my 5090, turned out my old motherboard had one bad pin. That was enough.
…or firmware: I’ve seen at least 2 instances in the last few months where upgrading mobo’s firmware helped. Also in the words of an NV eng:
So @lahdeero3363:
  • try this new 6254 firmware update from Asus for your mobo,
  • install the newest driver version (610.57.04) that may be bringing some fixes for GSP firmware,
  • monitor your thermals (maybe one of the fans or the thermal paste need to be replaced),
  • make sure your PSU is in fact able to provide enough juice.
I was able to run nvidia-bug-report.sh before rebooting when graphical session died. I guess I will update the firmware next..
nvidia-bug-report.log.gz (189.2 KB)
