System
- GPU: NVIDIA GeForce RTX 5090 Founders Edition
- Driver: 615.71.09
- Distribution: CachyOS
- Kernel: 7.2.6
- Desktop: KDE Plasma / KWin
- Session: Wayland
- Monitor: Samsung Odyssey Neo G9 57"
- Resolution: 7680×2160
- Refresh rate during latest reproduction: 240 Hz
- Connection: DisplayPort
nvidia_drmmodeset enabled
Problem
When KDE turns the monitor off through display power management and the display remains off for a long period (for example overnight), moving the mouse or pressing the keyboard does not restore the display.
The computer itself remains running and responsive. The KDE/Wayland session and kwin_wayland remain running.
I reproduced the problem on September 24, 2026. The first wake attempt was approximately 07:43 local time.
During/after the failure, the logs show KDE losing the physical output and creating a placeholder output. During subsequent DisplayPort recovery attempts, the kernel logged an NVIDIA modeset error including:
nvHandleCpEventDeferredWork: displayId 0x8000 invalid
KWin subsequently logged:
Applying output configuration failed!
and later:
Failed to open drm device
DisplayPort connector behavior
There is another unusual behavior during the same boot.
Initially the monitor was connected to one of the RTX 5090 FE DisplayPort connectors. After the failure, moving it to another DP connector could restore an output.
During subsequent testing in the same boot, previously used DP connectors stopped producing an image. Eventually DP1 and DP2 produced a black screen while DP3 could be used to obtain a TTY.
After additional connector testing, DP3 also produced a black screen.
I was able to recover without rebooting using the following sequence:
- Switch to a TTY with Ctrl+Alt+F4.
- If the TTY was still not visible, unplug/replug DisplayPort on DP3 while the TTY VT was selected.
- The TTY login screen then appeared.
- Log in and check
loginctl list-sessions. - The original KDE Wayland session was still online on tty1.
- Run
loginctl activate 1. - The existing KDE Wayland desktop immediately became visible again.
No reboot or KWin restart was required.
nvidia-smi continued to work during the problem and showed kwin_wayland still running.
Refresh-rate observation
I have also experienced the wake problem at 60 Hz. On that occasion, unplugging/replugging DisplayPort restored the display more easily. The latest reproduction was at 7680×2160 @ 240 Hz and was substantially harder to recover.
I do not yet know whether refresh rate is causal.
Expected behavior
The DisplayPort monitor should restore normally when keyboard or mouse input wakes a display that KDE has turned off.
Actual behavior
The monitor remains black/no-signal while the computer and Wayland session remain operational. DisplayPort connector/output state appears to become unusable until the VT/display link is recovered and the existing graphical session is explicitly reactivated.
I generated nvidia-bug-report.log.gz after reproducing and recovering from the problem, without rebooting, and have attached it.
kernel-live.log (27.1 KB)
nvidia-bug-report.log.gz (741.3 KB)
full-journal-after-failure.txt (578.9 KB)
user-live-snapshot-2026-09-24.txt (562.5 KB)
