GPU: RTX 4090
Driver: 527.37
I am observing a strange multi-monitor issue only occurring during boot, related to refresh rate:
My second monitor runs at 60Hz. I have a TV connected as a third monitor, and if it is set to 60Hz as well, everything works fine.
However, if my TV is set to a refresh rate other than 60Hz, e.g. 120Hz and is powered off, my second monitor gets disabled during boot.
Steps to reproduce:
- Connect two monitors and a TV.
- Set the second monitor to 60Hz.
- Set TV to a different refresh rate, e.g. 120Hz.
- Confirm that all screens are working at their respective refresh rates.
- Power off the TV.
- reboot the PC.
Result:
- First screen powered on and enabled.
- Second screen powered on but not enabled (blank screen, shows up in Windows and Driver as deactivated)
- TV powered off and also not enabled.
Notes:
- Powering on the TV after rebooting will re-enable both the TV and the second screen.
- The second screen should be independent of the power state of the TV, yet seems not to be.
- The problem occurs only if they have different refresh rates. If I set my TV to 60 Hz, power it off, and reboot, the second screen remains enabled.
- The high resolution is not the issue. If I set the TV to 59 Hz, and power it off, the second monitor is also disabled during reboot until the TV is powered.
- I believe this should be reproducible with any three screens. With a TV as the third screen, it can be ensured that it remains powered off during reboot, such that the issue can be reproduced reliably.
- The refresh rate of the first monitor seems to be no issue. My first monitor runs at 144Hz, a different refresh rate than the second monitor.
- While all three monitors are powered, running them at different refresh rates works fine.
