[BUG] STM report could not set cpuset when running cgf helloworld sample
Required Info:
  • Software Version
    DRIVE OS 6.0.6
  • Target OS
    Linux
  • SDK Manager Version
    1.9.2.10884
  • Host Machine Version
    native Ubuntu Linux 20.04 Host installed with DRIVE OS DOCKER Containers
Describe the bug
STM report could not set cpuset when running cgf helloworld sample.
To Reproduce
# goto target system which is orin devkit
cd ./nv_driveworks_demo/target/aarch64/install/example/dwcgf_helloworld/bin/
sudo ./run_cgf.sh
Expected behavior
Actual behavior
launcher.log, which is in here nv_driveworks_demo/launcher.log at 4a790d93544bee5b60306cc7697b3b6e9a90c546 · ZhenshengLee/nv_driveworks_demo · GitHub
[STM WARNING]:[av/stm/runtime/src/client/thread.c][stmStart] [398]: Could not set cpuset, setCpuset returned an error. errno=2 (No such file or directory)
Additional context
the sample work well with this warning.
Dear @lizhensheng,
Sample work well means, it exits with code ‘0’? Do you see prints from helloworld node in log?
@SivaRamaKrishnaNV
you can check helloworld node logs in nv_driveworks_demo/launcher.log at main · ZhenshengLee/nv_driveworks_demo (github.com)
there is also cpu related warnings in helloworld node logs.
But all cpuset related issue doesn’t interrupt the helloworld cgf app.
Friendly ping @SivaRamaKrishnaNV for updates.
Dear @lizhensheng ,
The [STM WARNING]… Could not set cpuset messages are showing up because STM’s client threads are trying to pin themselves to a specific CPU core when the cpuset files are not present on the board.
This message is non-fatal and indicates that STM’s threads are free running threads and that they are not pinned to a specific CPU core. Does this clarify?
