[BUG] sudo systemctl restart nv_nvsciipc_init.service failed without modifying any content of nvsciipc.cfg
Required Info:
  • Software Version
    DRIVE OS 6.0.8.1
  • Target OS
    Linux
  • SDK Manager Version
    1.9.2.10884
  • Host Machine Version
    native Ubuntu Linux 20.04 Host installed with DRIVE OS DOCKER Containers
Describe the bug
according to the doc of cgf Compute Graph Framework SDK Reference: Demo Pipeline Introduction we need to reinit the nvsciipc when the nvsciipc.cfg file is updated.
Please make sure there are 32 slots allocated inside the nvsciipc.cfg file. After the file has been updated, it is necessary to reboot the system for changes to take effect. To make sure the changes has been properly applied, please check with the following command:
sudo service nv_nvsciipc_init status should print message below:
‍nv_nvsciipc_init.service - NvSciIpc initialization
Loaded: loaded (/lib/systemd/system/nv_nvsciipc_init.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Wed 2021-06-16 20:36:43 UTC; 52min ago
Process: 758 ExecStart=/bin/sh /etc/systemd/scripts/nv_nvsciipc_init.sh (code=exited, status=0/SUCCESS)
Main PID: 758 (code=exited, status=0/SUCCESS)
If not, please double check your nvsciipc.cfg file.
we found that /etc/systemd/scripts/nv_nvsciipc_init.sh always return error.
To Reproduce
# good
# report error
Job for nv_nvsciipc_init.service failed because the control process exited with error code.
See "systemctl status nv_nvsciipc_init.service" and "journalctl -xe" for details.
Expected behavior
sudo systemctl restart nv_nvsciipc_init.service should works well.
Actual behavior
the service report failed after manual restarting the service
systemctl is-failed nv_nvsciipc_init.service
failed
Additional context
reboot the machine should fix the failure
Dear @lizhensheng,
I can reproduce the issue. I will check internally and get back to you.
Dear @lizhensheng,
I can see the recommendation is to reboot the system after file update in documentation. Are you asking why reboot is needed instead of restarting the service?
Yes, I report the issue to the forum.
