System Information
Laptop: Lenovo ThinkPad T490 (20N3S1GL00)
CPU: Intel Core i5-8365U
GPU: NVIDIA GeForce MX250 (GP108M)
GPU VBIOS: 86.08.3B.00.39
Operating System: Ubuntu 24.04.5 LTS
Kernel: 7.0.0-38-generic
NVIDIA Driver: 580.178.04
Kernel Module: Proprietary NVIDIA module
Desktop: GNOME / X11
BIOS: N2IETA7W (1.85)
Embedded Controller: N2IHT32W
Problem Description
My NVIDIA GeForce MX250 is stuck at a maximum operating-temperature threshold of 57°C, causing severe GPU throttling and performance degradation.
The GPU previously operated with a 75°C target temperature, but the threshold has repeatedly reverted to 57°C.
The problem affects multiple games, including Team Fortress 2 and Call of Duty: Black Ops II.
During gaming, I have observed:
GPU utilization reaching 100%.
GPU graphics clocks dropping to approximately 139 MHz.
Severe frame-rate drops, sometimes to approximately 30 FPS.
NVIDIA reporting software thermal slowdown as active.
This happens even when the GPU temperature is relatively low.
NVIDIA Temperature Readings
Output from nvidia-smi -q -d TEMPERATURE:
GPU Current Temp : 46 C
GPU Slowdown Temp : 97 C
GPU Target Temperature : 57 C
Output from nvidia-settings -q GPUMaxOperatingTempThreshold:
Attribute 'GPUMaxOperatingTempThreshold':
57.
'GPUMaxOperatingTempThreshold' is a read-only attribute.
The reported maximum operating-temperature threshold is therefore 57°C, despite the GPU reporting a slowdown temperature of 97°C.
Troubleshooting Already Performed
1. NVIDIA Driver
Updated the NVIDIA driver to version 580.178.04.
The problem persists.
Ubuntu currently lists these driver packages as available:
nvidia-driver-580
nvidia-driver-580-server
The installed driver uses the proprietary NVIDIA kernel module.
2. NVIDIA Temperature Target Override
Attempted:
sudo nvidia-smi -i 0 -gtt 75
The driver responded:
GPU Target Temperature Threshold not supported
for GPU 00000000:3C:00.0.
The GPU target remained at 57°C.
3. ThinkPad Platform Performance Mode
Set:
/sys/firmware/acpi/platform_profile
to:
performance
Also attempted switching from balanced back to performance.
Neither restored the 75°C GPU threshold.
4. ThinkPad DYTC Lap Mode
The ThinkPad initially reported:
dytc_lapmode = 1
After investigating the firmware’s DYTC controls, the value subsequently changed to:
dytc_lapmode = 0
However, the NVIDIA maximum operating-temperature threshold remained at 57°C.
The system exposes dytc_lapmode as a read-only sysfs attribute and does not expose a dytc_perfmode attribute.
5. ACPI Methods
Investigated the laptop’s ACPI tables using acpidump, acpixtract, and iasl.
Attempted the ThinkPad ACPI performance method _Q6D.
Also investigated the DYTC firmware interface through the acpi_call kernel module.
One DYTC call returned:
0x20017d01
These attempts did not restore the GPU’s 75°C temperature threshold.
6. thermald
The thermald package is installed, but its service exits because it considers this ThinkPad platform unsupported.
Relevant log messages:
[/sys/devices/platform/thinkpad_acpi/dytc_lapmode]
present: Thermald can't run on this platform
Unsupported cpu model or platform
7. BIOS Configuration
Entered the ThinkPad BIOS and attempted adjustments to available settings.
I could not find an Intelligent Cooling Boost option.
The BIOS adjustments I attempted did not affect the NVIDIA temperature threshold.
8. Complete Power Reset — Previously Worked, Now Fails
This is one of the most important observations.
Previously, I could temporarily restore the GPU target temperature to 75°C by:
Shutting down the laptop.
Disconnecting AC power.
Holding the power button for approximately 30 seconds.
Waiting before powering the laptop back on.
After this procedure, NVIDIA previously reported:
GPU Current Temp : 49 C
GPU Target Temperature : 75 C
Unfortunately, this workaround no longer works.
I have repeated the power-button reset procedure with AC power disconnected, but the NVIDIA temperature target remains stuck at 57°C.
I have also restarted the laptop, entered the BIOS, and attempted configuration changes without success.
The issue now persists across restarts and the previously successful power-reset procedure.
Current Status
As of now:
NVIDIA driver: 580.178.04
Linux kernel: 7.0.0-38-generic
GPU target temperature: 57°C
GPU slowdown temperature: 97°C
ThinkPad platform profile: performance
Last observed DYTC lap-mode state: 0
Previous 75°C recovery workaround: no longer effective
BIOS adjustments: unsuccessful
The GPU remains functional but experiences substantial performance degradation during demanding workloads.
Expected Behavior
The MX250 should operate according to its intended thermal and power-management policy without becoming persistently restricted to an unusually low temperature threshold.
Previously, the system reported a 75°C GPU target temperature.
I would like to restore that behavior using a supported method.
Questions for NVIDIA
What determines the MX250’s
GPUMaxOperatingTempThresholdvalue on this ThinkPad? -
Why does the reported threshold alternate between 57°C and 75°C?
Could Lenovo’s embedded controller, ACPI firmware, or Dynamic Thermal Control (DYTC) interface be influencing the threshold reported by the NVIDIA driver?
Why did a complete power reset previously restore 75°C, but no longer do so?
Is there a supported Linux driver or firmware interface for restoring the correct thermal policy?
Is this a known issue involving the ThinkPad T490, MX250, and NVIDIA 580 driver series?
I understand that the GPU temperature threshold may be controlled by laptop firmware rather than directly by the NVIDIA driver.
However, I would appreciate assistance identifying the responsible component and determining whether this behavior can be corrected.
