Required Info:
- Software Version
DRIVE OS 6.0.6 - Target OS
Linux - SDK Manager Version
1.9.2.10884 - Host Machine Version
native Ubuntu Linux 20.04 Host installed with DRIVE OS DOCKER Containers
Describe the bug
version-checker pcie_retimer failed, ‘/etc/nvidia/version_checker/manifest/pcie_retimer.yml’
To Reproduce
nvidia@tegra-ubuntu:~/zhensheng/orin_ws/nv_driveworks_demo/target$ sudo version_checker_root.py -i /etc/nvidia/version_checker/manifest/version_data_root.yml
ROOT VERSION CHECKER
Invoking python3 /usr/sbin/version_checker_leaf.py -i /etc/nvidia/version_checker/manifest/rootfs_debians.yml -b 940-63710-0010-000 -s 6.0.6.0-32441545
Start checking version of "Filesystem debian packages".
*** Rootfs Manifest could not be read. ***
Finished checking version of "Filesystem debian packages".
Invoking python3 /usr/sbin/version_checker_leaf.py -i /etc/nvidia/version_checker/manifest/ethernet_firmware_1.yml -b 940-63710-0010-000 -s 6.0.6.0-32441545
Start checking version of "Oak Eth Switch SPI Config ROM SMI_ADDRESS=8".
Invoking /bin/bash -c '/lib/firmware/marvell_ethernet/common/ota/linux/nvidia/update-firmware.sh --printversion | grep "Full firmware version at SMI_ADDRESS=8:"| cut -d" " -f6'
*** Version matches on firmware "Oak Eth Switch SPI Config ROM SMI_ADDRESS=8", expected and found 00.07.1186.01 ***
Finished checking version of "Oak Eth Switch SPI Config ROM SMI_ADDRESS=8".
Invoking python3 /usr/sbin/version_checker_leaf.py -i /etc/nvidia/version_checker/manifest/ethernet_firmware_2.yml -b 940-63710-0010-000 -s 6.0.6.0-32441545
Start checking version of "Spruce Eth Switch SPI Config ROM SMI_ADDRESS=4".
Invoking /bin/bash -c '/lib/firmware/marvell_ethernet/common/ota/linux/nvidia/update-firmware.sh --printversion | grep "Full firmware version at SMI_ADDRESS=4:"| cut -d" " -f6'
*** Version matches on firmware "Spruce Eth Switch SPI Config ROM SMI_ADDRESS=4", expected and found 00.07.1186.01 ***
Finished checking version of "Spruce Eth Switch SPI Config ROM SMI_ADDRESS=4".
Invoking python3 /usr/sbin/version_checker_leaf.py -i /etc/nvidia/version_checker/manifest/ethernet_firmware_3.yml -b 940-63710-0010-000 -s 6.0.6.0-32441545
Invoking python3 /usr/sbin/version_checker_leaf.py -i /etc/nvidia/version_checker/manifest/ethernet_phy_firmware_1.yml -b 940-63710-0010-000 -s 6.0.6.0-32441545
Invoking python3 /usr/sbin/version_checker_leaf.py -i /etc/nvidia/version_checker/manifest/ethernet_phy_firmware_2.yml -b 940-63710-0010-000 -s 6.0.6.0-32441545
Invoking python3 /usr/sbin/version_checker_leaf.py -i /etc/nvidia/version_checker/manifest/ethernet_cx6-dx_firmware.yml -b 940-63710-0010-000 -s 6.0.6.0-32441545
Start checking version of "Mellanox CX-DX6 ethernet NIC on P4024".
*** No compatible board found for firmware "Mellanox CX-DX6 ethernet NIC on P4024". ***
*** Skipping version check for firmware "Mellanox CX-DX6 ethernet NIC on P4024". ***
Finished checking version of "Mellanox CX-DX6 ethernet NIC on P4024".
Invoking python3 /usr/sbin/version_checker_leaf.py -i /etc/nvidia/version_checker/manifest/aurix_firmware_1.yml -b 940-63710-0010-000 -s 6.0.6.0-32441545
Start checking version of "AURIX Safety MCU AFW".
Invoking /bin/bash -c 'common_if_testapp -get_fw_version | grep "Flashed AURIX fw version" | cut -d" " -f5'
*** Version matches on firmware "AURIX Safety MCU AFW", expected and found 5.07.06.00 ***
Finished checking version of "AURIX Safety MCU AFW".
Invoking python3 /usr/sbin/version_checker_leaf.py -i /etc/nvidia/version_checker/manifest/aurix_firmware_2.yml -b 940-63710-0010-000 -s 6.0.6.0-32441545
Start checking version of "AURIX Safety MCU UPDATE FW".
Invoking /bin/bash -c 'common_if_testapp -get_update_fw_version | grep "Flashed UPDATE fw version" | cut -d" " -f5'
*** Version matches on firmware "AURIX Safety MCU UPDATE FW", expected and found 1.48.01.00 ***
Finished checking version of "AURIX Safety MCU UPDATE FW".
Invoking python3 /usr/sbin/version_checker_leaf.py -i /etc/nvidia/version_checker/manifest/pcie_retimer.yml -b 940-63710-0010-000 -s 6.0.6.0-32441545
Root version checker returned -1.
nvidia@tegra-ubuntu:~/zhensheng/orin_ws/nv_driveworks_demo/target$ sudo /usr/sbin/version_checker_leaf.py -i /etc/nvidia/version_checker/manifest/pcie_retimer.yml -b 940-63710-0010-000 -s 6.0.6.0-32441545
File "/usr/sbin/version_checker_leaf.py", line 248, in <module>
leaf_version_checker = LeafVersionChecker(config_file=YAML_FILE,
File "/usr/sbin/version_checker_leaf.py", line 56, in __init__
yaml_data = self.read_config(config_file)
File "/usr/sbin/version_checker_root.py", line 156, in read_config
with open(yaml_file, 'r') as file:
FileNotFoundError: [Errno 2] No such file or directory: '/etc/nvidia/version_checker/manifest/pcie_retimer.yml'
Expected behavior
we can check the version of pcie_retimer.
Actual behavior
Additional context
the firmware is updated with the command and report no error.
sudo /usr/lib/firmware/astera_retimer/tools/eeprom /usr/lib/firmware/astera_retimer/firmware/pt4080l/1.25.x/nvidia_p3713_x4x4/nvidia_P3713_x4x4_X8-B2B_RETIMER-DYN_PRT_ORIENT-SRNS-CLK_IND-HOT_PLUG-GPIO_PERST_v1_25_9.ihx
