Bug with CUDA 2.3 Emulation mode only after reboot
I have a problem on my macPro with 8800GTS. I install cuda 2.3 with this method:
  • toolkit
  • driver
  • sdk
After that, I can launch deviceQuery and it display my 8800GTS. But after a reboot, the result of deviceQuery is “There is no device supporting CUDA”. So I reinstall the driver and it works fine. But after the next reboot the problem is coming back…
What can I do?
Thx for any help.
ps: sorry for my bad english, I’m french.
I’m getting this problem too, did you find a solution?
sorry.
older thread found.
Thanks for your help, the solution is to copy and past both commandlines in a terminal.
sudo chmod g-w /System/Library/StartupItems/CUDA/*
