I’m having a strange issue while trying to rebuild the sample rectifier even if i use the geniune main.cpp file:
terminate called after throwing an instance of ‘std::runtime_error’
what(): GenericSimpleFormatConverter: Unsupported input type
This is what i have when i use gdb:
#0 0x0000007fb395b528 in __GI_raise (sig=sig@entry=6)
at …/sysdeps/unix/sysv/linux/raise.c:54 #1 0x0000007fb395c9e0 in __GI_abort () at abort.c:89 #2 0x0000007fb3bcf6c8 in __gnu_cxx::__verbose_terminate_handler() ()
from /usr/lib/aarch64-linux-gnu/libstdc++.so.6 #3 0x0000007fb3bcd444 in ?? () from /usr/lib/aarch64-linux-gnu/libstdc++.so.6 #4 0x0000007fb3bcd490 in std::terminate() ()
from /usr/lib/aarch64-linux-gnu/libstdc++.so.6 #5 0x0000007fb3bcd714 in __cxa_throw () from /usr/lib/aarch64-linux-gnu/libstdc++.so.6 #6 0x00000000004284b4 in dw_samples::common::GenericSimpleFormatConverter::GenericSimpleFormatConverter(dwImageProperties const&, dwImageProperties const&, dwContextObject*)
() #7 0x0000000000424a88 in dw_samples::common::SimpleCamera::enableGLOutput() () #8 0x00000000004155e8 in RectifierApp::initCameras() () #9 0x0000000000415978 in RectifierApp::onInitialize() () #10 0x0000000000417b38 in dw_samples::common::DriveWorksSample::run() () #11 0x000000000041483c in main ()
After some research i still have this issue, and if i use the default application it doesn’t take the values of distortion stored in the rig.xml file and the image isn’t undistorted.
To rectificate my videos i used the sample stereo_rectifier which works well for my Sekonix fisheye cameras (Sekonix SF 3325-100 [60°] and Sekonix SF 3324-100 [120°]). With stereo_rectifier i can’t use the option --single-input=1, the program correctly launch but crash saying “Segmentation fault (core dumped)” even with the default application.
Yes i first made modifications to put directly the path of my rig.xml and i wasn’t working so i used the original code I previously saved and it wasn’t working!
The rig.xml used by the application is /samples/sfm/triangulation/rig.xml
As this app wasn’t useful i rebuilt the Stereo_rectifier with my custom rig.xml and it worked perfectly so i retried with the rectifier but no good results.
There are two applications: sample_rectifier and sample_stereo_rectifier.
What i want is to be able to display one of my video file rectified, i can rectify the image with the second one but it displays 2 videos! And as i said before the option --single-input=1 doesn’t work.
Dear AdrienBonefons,
The --single-input=1 option needs to be used for only single stereo images. The cameras SF3324-100 and SF3325-100 are not stereo cameras. So you need to give two individual cameras as input and -single-input=1 does not work
You can not use --single-input option for the camera type you have(SF3324-100,SF3325-100). You need to have stereo camera which produces single stereo image to use this option.
For sample_rectifier, Can you please file a bug with code and steps to reproduce the error and share ID here to follow up?
