[Bug] Xid 62 GSP Watchdog Timeout on RTX 5080 during high-context LLM inference
Hardware: NVIDIA GeForce RTX 5080 (16GB)
Driver Version: 595.71.05 (Open Kernel Module)
OS: Proxmox VE 9.1.11 (Kernel 7.0.2-3-pve / Debian 12 based)
Workload: LLM Inference (llama.cpp)
1. Problem Description
The GPU enters an unrecoverable state (Xid 62) during high-context LLM inference tasks. The failure is highly deterministic and specifically reproducible when using Multi-Token Prediction (MTP) model architectures (e.g., Qwen3.6-35B-MTP) at context windows $\ge$ 128k. Standard MoE and Dense models are perfectly stable, suggesting a logic bug in the GSP scheduler when handling the specific tensor scheduling required by MTP architectures on Blackwell.
2. Environment & Mitigations (Active during crash)
To rule out environmental or hardware defects, this system operates with strict constraints. The crash occurred despite these active mitigations:
  • Power Capping: Active power limit set to 288 W (80% of 360 W TDP) via nvidia-smi -pl 288 to prevent transient voltage spikes.
  • Thermal Management: GPU temperature at the exact time of the crash was a very cool 52°C. Active cooling was running at 92% fan speed.
  • Persistence Mode: nvidia-persistenced was actively running on the host.
  • Isolation: The workload was running with direct GPU passthrough; no concurrent GPU processes were active on the host or in other containers.
3. Error Logs (GSP-CrashCat)
The GSP firmware consistently fails in the exact same scheduler thread across multiple incidents.
  • GSP Build ID: 6332050fe14352839619385982f83700835ef570
  • GSP Task: partition:4#0, task:3 (RISC-V Scheduler)
  • Forensic Address: GSP task watchdog timeout @ pc:0x1b3e200
Kernel Trace:
NVRM: Xid (PCI:0000:01:00): 62, 323f0f30 0000c3d8 00000000 206dae68 206da022 206da190 206d85f6 206d8d86
NVRM: GPU0 _kgspRpcGspEventPmuHalted: Received signal from GSP that PMU has halted.
NVRM: Xid (PCI:0000:01:00): 154, GPU recovery action changed from 0x0 (None) to 0x1 (GPU Reset Required)
NVRM: GPU0 kgspHealthCheck_TU102: ********** GSP-CrashCat Report ***********
NVRM: RISC-V CSR State: sstatus:0x0000000200000020 sscratch:0xffffffffa3013970 sie:0x0000000000000220 sip:0x0000000000000020
GSP task watchdog timeout @ pc:0x1b3e200, partition:4#0, task:3
4. Steps to Reproduce
  1. Load Qwen3.6-35B-A3B-MTP-GGUF (IQ2_M or Q2_K_XL).
  2. Set context size to 131,072.
  3. Set flash-attn = on and fit = on in llama.cpp.
  4. The GSP will reliably crash during the “fitting params to device memory” phase, even when VRAM usage is ~13.3 GB (leaving nearly 3 GB of physical headroom).
5. Technical Conclusion
The presence of strict power capping and stable, low thermals (52°C) at the time of failure strongly indicates that this is not a hardware overheating or power-delivery issue.
The deterministic nature of the crash (specific to MTP architectures and high context fitting) points to a firmware scheduler regression/deadlock in the 595.xx Blackwell GSP driver branch.
I have attached the nvidia-bug-report-2026-05-24.log.gz (768.3 KB) generated immediately after the Xid 62 event.
Just wanted to throw in, I got some Xid 62s on my GTX1650. I was running 595.71.05 then (after I realized I had accidentally pinned the driver, I do prefer to run ‘latest and greatest’) later running 610.43.02. In my case, it was under light load, youtube video playing popped out with light (i.e. non-gaming) desktop use. Xid 62, “Received signal from GSP that PMU has halted” then just messages about stuff timing out + that chip status is “NV_ERR_GPU_IN_FULLCHIP_RESET”.)
I dropped from 7.0.x kernel (I was on 7.0.10 before I reverted – Zabbly kernel which is “stock kernel built with stock Ubuntu kernel config”, i.e. it’s not all patched up) to the 6.17.0-35 distro kernel (this is on Ubuntu 24.04), no freezes. I also saw firefox crashes I think under memory pressure, which I assumed was a firefox bug but that quit happening once I downgraded the kernel too.
Worth a shot!
Follow-up Update (2026-07-06)
TL;DR — Xid 62 issue persisted despite power limit mitigation; transitioned to hard error state requiring PSU power cycle for recovery. New data point suggests hardware-level thermal/power-delivery involvement beyond firmware scheduler regression.
Extended Timeline & Incident Escalation
Previous Report (2026-05-25)
  • Reproducible failure: MTP models (Qwen3.6-35B-MTP) at context ≥128k with flash-attn=on, fit=on
  • Power state: 288W power limit (80% TDP)
  • Thermal state: 52°C at crash time
  • Recovery: Required host reboot
Mitigation Deployment (2026-05-22 to 2026-07-04)
  • Reduced power limit: 288W → 260W (−7.8%)
  • Deployed Grafana GPU alerting (temp, power, utilization thresholds)
  • Enhanced watchdog with soft-recovery (PCIe FLR) + email notification
  • Ran stable inference for 40+ days at reduced power
Incident Recurrence (2026-07-05 20:23 UTC)
During routine benchmarking (not MTP architecture), GPU transitioned to hard error state:
  • Model: Qwen3.6-35B-A3B (dense, non-MTP)
  • Power draw: Not stuck at ceiling (soft recovery occurred, then hard error)
  • VRAM state: 13.5/16 GB held, no running processes visible
  • Status: ERR! ERR! ERR! across all nvidia-smi metrics
Escalation attempts:
  1. Power limit reduction: 260W → 250W (−3.8%)
    • Result: ❌ Hard error persisted despite 250W limit being set
  2. Driver reload via systemctl isolate rescue
    • Result: ⚠️ Temporary VRAM clear (13.5GB → 2MB) but error returned
  3. Software reboot with 250W enforced
    • Result: ❌ GPU remained in error state post-reboot; nvidia-smi -r reports “Not Supported”
  4. Full PSU power cycle (10-hour offline period)
    • Result: ✅ Hard error cleared completely
Post-recovery GPU status (2026-07-06 06:33 UTC):
GPU 0  RTX 5080        On   |   0%   38C    P8             12W /  250W
Memory 13.3GB / 16.3GB loaded (llama.cpp running normally)
Power Limit: 250W (persisted across reboot)
Root Cause Analysis Update
Original Hypothesis (2026-05-25)
  • GSP firmware scheduler deadlock specific to MTP tensor scheduling at high context
  • Power capping (288W) and low thermals ruled out firmware thermal throttle
Revised Hypothesis (2026-07-06)
The July 5 incident introduces new data:
  1. Hard error unrecoverable by software alone suggests power-delivery or thermal-sensor latch
    • Power limit reduction alone insufficient (error persisted at 250W)
    • Software GPU reset not supported by RTX 5080 driver
    • Full PSU power cycle was required recovery path
  2. Error occurred on non-MTP architecture suggests scope beyond MTP + high-context
    • May indicate broader scheduler issue OR
    • Thermal sensor saturation/hysteresis causing GSP watchdog timeout across all architectures
  3. Transient nature (recovered after PSU cycle) suggests:
    • Hardware thermal sensor latch (capacitor charge retention)
    • Phase-change material (PCM) thermal hysteresis on GPU module
    • Latched power-delivery fault (voltage regulator in shutdown state)
Evidence Summary
Incident Model Context Power Temp Recovery Method
2026-05-06 to 2026-05-22 (4 crashes) MTP 128k 288W 52°C Host reboot
2026-07-05 (this incident) Dense 131k 260W → 250W (not logged) PSU power cycle
New Findings & Recommendations
Finding 1: Power Capping Incomplete Mitigation
  • Evidence: 260W→250W limit reduction did not prevent hard error; error persisted even at 250W
  • Implication: Hardware may be hitting physical power delivery limits (VRM saturation) despite firmware power-limit cap
  • Next step: Check if power limit enforcement is working at PCIe/VRM level (query nvidia-smi -q | grep Power during load)
Finding 2: Thermal Sensor Possible Culprit
  • Evidence: Hard error cleared only after PSU power cycle (capacitor drain time ~30-60s)
  • Implication: Thermal sensor may have latched into shutdown state; requires full rail discharge to clear
  • Recommendation: Thermal imaging of GPU module after error state; check power delivery stage temperatures
Testing Recommendations for NVIDIA
  1. Reproduce on Reference Platform:
    • NVIDIA test platform: RTX 5080 FE, fresh 250W/600W PSU
    • Load high-context (131k+) dense and MTP models continuously for 24h
    • Monitor: GSP watchdog timeout frequency, thermal sensor readings, power delivery voltages
  2. Thermal Sensor Investigation:
    • Capture GSP CrashCat thermal sensor values at time of crash
    • Compare against sensor saturation thresholds in firmware
    • Check for hysteresis logic (sensor latching into shutdown state)
  3. Power Delivery Margin Analysis:
    • Measure actual VRM output voltage during peak inference (should stay within 0.5-1.0V margin)
    • Compare against firmware power-limit enforcement vs. actual VRM ceiling
    • May indicate under-specified VRM for Blackwell Gigahertz clock speeds at full context load
Questions for NVIDIA Engineering
  1. Does RTX 5080 GSP firmware support dynamic thermal sensor recalibration?
  2. Can firmware distinguish between power-delivery fault vs. thermal transient?
  3. Are there known VRM saturation issues on RTX 5080 at 600W+ PSUs with sustained >90% utilization?
  4. Would VBIOS/GSP firmware update 610.43.02 → 620.xx (if available) include watchdog timeout fixes?
System Info:
  • GPU: NVIDIA GeForce RTX 5080 (16GB GDDR7)
  • Driver: 610.43.02 (CUDA 13.2, May 15 2026)
  • GSP Build: 6332050fe14352839619385982f83700835ef570
  • Host: Proxmox VE 9.2.0 (Kernel 7.0.14-3-pve)
  • PSU: 850W 80+ Platinum
  • Workload: llama.cpp LLM inference (Qwen 35B models, 131k context)
Bug Report Attachment: nvidia-bug-report-2026-07-05.log.gz (760 Bytes)
Will provide additional data if kernel watchdog events or thermal sensor logs can be extracted from GSP CrashCat dumps.
In the meantime – will downgrade to the 6.17 kernel to see if this stupidly expensive card gets any more usable… don’t know if it’s a solution, but will stop me from having to be NVIDIA’s guinea pig…
can you let me know what driver version you’re running? i tested on the older kernel today. (6.17.13-14).. still failed pretty quick:
root@pve:~# apt list --installed| grep nvidia
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
firmware-nvidia-gsp/unknown,now 610.43.02-1 amd64 [installed]
libegl-nvidia0/unknown,now 610.43.02-1 amd64 [installed,automatic]
libgles-nvidia1/unknown,now 610.43.02-1 amd64 [installed,automatic]
libgles-nvidia2/unknown,now 610.43.02-1 amd64 [installed,automatic]
libglx-nvidia0/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-allocator1/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-api1/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-cfg1/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-egl-gbm1/unknown,now 1.1.3-1 amd64 [installed,automatic]
libnvidia-egl-wayland21/unknown,now 1.0.1-1 amd64 [installed,automatic]
libnvidia-egl-xcb1/unknown,now 1:1.0.5-1 amd64 [installed,automatic]
libnvidia-egl-xlib1/unknown,now 1:1.0.5-1 amd64 [installed,automatic]
libnvidia-eglcore/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-encode1/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-fbc1/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-glcore/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-glvkspirv/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-gpucomp/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-ml1/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-ngx1/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-nvvm4/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-nvvm704/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-opticalflow1/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-pkcs11-openssl3/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-present/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-ptxjitcompiler1/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-rtcore/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-sandboxutils/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-tileiras/unknown,now 610.43.02-1 amd64 [installed,automatic]
libnvidia-vksc-core/unknown,now 610.43.02-1 amd64 [installed,automatic]
nvidia-cuda-toolkit-doc/stable,now 12.4.1-2 all [installed,automatic]
nvidia-driver-cuda/unknown,now 610.43.02-1 amd64 [installed]
nvidia-driver-libs/unknown,now 610.43.02-1 amd64 [installed,automatic]
nvidia-driver/unknown,now 610.43.02-1 amd64 [installed]
nvidia-egl-icd/unknown,now 610.43.02-1 amd64 [installed,automatic]
nvidia-kernel-open-dkms/unknown,now 610.43.02-1 amd64 [installed]
nvidia-kernel-support/unknown,now 610.43.02-1 amd64 [installed,automatic]
nvidia-modprobe/unknown,now 610.43.02-1 amd64 [installed,automatic]
nvidia-opencl-icd/unknown,now 610.43.02-1 amd64 [installed,automatic]
nvidia-openjdk-8-jre/stable,now 9.+8u452-ga-1~12.4.1-2 amd64 [installed,automatic]
nvidia-persistenced/unknown,now 610.43.02-1 amd64 [installed,automatic]
nvidia-powerd/unknown,now 610.43.02-1 amd64 [installed,automatic]
nvidia-profiler/stable,now 12.4.127~12.4.1-2 amd64 [installed,automatic]
nvidia-settings/unknown,now 610.43.02-1 amd64 [installed]
nvidia-vdpau-driver/unknown,now 610.43.02-1 amd64 [installed,automatic]
nvidia-visual-profiler/stable,now 12.4.127~12.4.1-2 amd64 [installed]
nvidia-vulkan-icd/unknown,now 610.43.02-1 amd64 [installed,automatic]
xserver-xorg-video-nvidia/unknown,now 610.43.02-1 amd64 [installed,automatic]
root@pve:~# uname -a
Linux pve 6.17.13-14-pve #1 SMP PREEMPT_DYNAMIC PMX 6.17.13-14 (2026-06-23T12:24Z) x86_64 GNU/Linux
root@pve:~# nvidia-smi -q
==============NVSMI LOG==============
Timestamp                                              : Mon Jul  6 17:49:54 2026
Driver Version                                         : 610.43.02 [Deprecated; will be removed in CUDA 14.0. Use KMD Version instead]
CUDA Version                                           : 13.3 [Deprecated; will be removed in CUDA 14.0. Use CUDA UMD Version instead]
KMD Version                                            : 610.43.02
CUDA UMD Version                                       : 13.3
Attached GPUs                                          : 1
GPU 00000000:01:00.0
    Product Name                                       : NVIDIA GeForce RTX 5080
    Product Brand                                      : GPU requires reset
    Product Architecture                               : Blackwell
    Display Mode                                       : Requested functionality has been deprecated
    Display Attached                                   : N/A
    Display Active                                     : N/A
    Persistence Mode                                   : Enabled
    Addressing Mode                                    : HMM
    MIG Mode
        Current                                        : GPU requires reset
        Pending                                        : GPU requires reset
    Accounting Mode                                    : N/A
    Accounting Mode Buffer Size                        : N/A
    Driver Model
        Current                                        : N/A
        Pending                                        : N/A
    Serial Number                                      : 0
    GPU UUID                                           : GPU-8de3170d-9c5e-d7cc-b1b9-ad0a989818ba
    GPU PDI                                            : GPU requires reset
    Minor Number                                       : 0
    VBIOS Version                                      : 98.03.3B.C0.40
    MultiGPU Board                                     : N/A
    Board ID                                           : N/A
    Board Part Number                                  : N/A
    GPU Part Number                                    : 2C02-400-A1
    FRU Part Number                                    : N/A
    Platform Info
        Chassis Serial Number                          : GPU requires reset
        Slot Number                                    : GPU requires reset
        Tray Index                                     : GPU requires reset
        Host ID                                        : GPU requires reset
        Peer Type                                      : GPU requires reset
        Module Id                                      : GPU requires reset
        GPU Fabric GUID                                : GPU requires reset
    Inforom Version
        Image Version                                  : N/A
        OEM Object                                     : N/A
        ECC Object                                     : N/A
        Power Management Object                        : N/A
    Inforom BBX Object Flush
        Latest Timestamp                               : N/A
        Latest Duration                                : N/A
    Inforom Time Data
        Time Run                                       : N/A
    GPU Operation Mode
        Current                                        : N/A
        Pending                                        : N/A
    GPU C2C Mode                                       : GPU requires reset
    GPU Virtualization Mode
        Virtualization Mode                            : N/A
        Host VGPU Mode                                 : N/A
        vGPU Heterogeneous Mode                        : N/A
    GPU Recovery Action                                : Reset
    GSP Firmware Version                               : 610.43.02
    IBMNPU
        Relaxed Ordering Mode                          : N/A
    PCI
        Bus                                            : 0x01
        Device                                         : 0x00
        Domain                                         : 0x0000
        Base Classcode                                 : 0x3
        Sub Classcode                                  : 0x0
        Device Id                                      : 0x2C0210DE
        Bus Id                                         : 00000000:01:00.0
        Sub System Id                                  : 0x89E01043
        GPU Link Info
            PCIe Generation
                Max                                    : N/A
                Current                                : N/A
                Device Current                         : N/A
                Device Max                             : N/A
                Host Max                               : N/A
            Link Width
                Max                                    : N/A
                Current                                : N/A
        Bridge Chip
            Type                                       : N/A
            Firmware                                   : N/A
        Replays Since Reset                            : GPU requires reset
        Replay Number Rollovers                        : GPU requires reset
        Tx Throughput                                  : GPU requires reset
        Rx Throughput                                  : GPU requires reset
        Atomic Caps Outbound                           : N/A
        Atomic Caps Inbound                            : FETCHADD_32 FETCHADD_64 SWAP_32 SWAP_64 CAS_32 CAS_64
    Fan Speed                                          : GPU requires reset
    Performance State                                  : GPU requires reset
    Clocks Event Reasons                               : N/A
    Clocks Event Reasons Counters
        SW Power Capping                               : GPU requires reset
        Sync Boost                                     : GPU requires reset
        SW Thermal Slowdown                            : GPU requires reset
        HW Thermal Slowdown                            : GPU requires reset
        HW Power Braking                               : GPU requires reset
    Sparse Operation Mode                              : GPU requires reset
    FB Memory Usage
        Total                                          : 16303 MiB
        Reserved                                       : 423 MiB
        Used                                           : 17 MiB
        Free                                           : 15865 MiB
    BAR1 Memory Usage
        Total                                          : N/A
        Used                                           : N/A
        Free                                           : N/A
    Conf Compute Protected Memory Usage
        Total                                          : 0 MiB
        Used                                           : 0 MiB
        Free                                           : 0 MiB
    Compute Mode                                       : Default
    Utilization
        GPU                                            : N/A
        Memory                                         : N/A
        Encoder                                        : N/A
        Decoder                                        : N/A
        JPEG                                           : N/A
        OFA                                            : N/A
    Encoder Stats
        Active Sessions                                : N/A
        Average FPS                                    : N/A
        Average Latency                                : N/A
    FBC Stats
        Average FPS                                    : N/A
    DRAM Encryption Mode
        Current                                        : N/A
        Pending                                        : N/A
    ECC Mode
        Current                                        : N/A
        Pending                                        : N/A
    ECC Errors
        Volatile
            SRAM Correctable                           : N/A
            SRAM Uncorrectable Parity                  : N/A
            SRAM Uncorrectable SEC-DED                 : N/A
            DRAM Correctable                           : N/A
            DRAM Uncorrectable                         : N/A
        Aggregate
            SRAM Threshold Exceeded                    : N/A
        Aggregate Uncorrectable SRAM Sources
            SRAM L2                                    : N/A
            SRAM SM                                    : N/A
            SRAM Microcontroller                       : N/A
            SRAM PCIE                                  : N/A
            SRAM Other                                 : N/A
        Channel Repair Pending                         : GPU requires reset
        TPC Repair Pending                             : GPU requires reset
        Unrepairable Memory                            : GPU requires reset
    Retired Pages
        Single Bit ECC                                 : N/A
        Double Bit ECC                                 : N/A
        Pending Page Blacklist                         : N/A
    Remapped Rows                                      : GPU requires reset
    Temperature
        GPU Current Temp                               : GPU requires reset
        GPU Current T.Limit Temp                       : GPU requires reset
        GPU Shutdown T.Limit Temp Specification        : GPU requires reset
        GPU Slowdown T.Limit Temp Specification        : GPU requires reset
        GPU Max Operating T.Limit Temp Specification   : 0 C
        GPU Target Temperature Specification           : N/A
        Memory Current Temp                            : N/A
        Memory Max Operating T.Limit Temp Specification: GPU requires reset
    GPU Power Readings
        Average Power Draw                             : GPU requires reset
        Instantaneous Power Draw                       : GPU requires reset
        GPU Ceiling Power Limit
            Current Power Limit                        : Unknown Error
            Requested Power Limit                      : Unknown Error
            Default Power Limit                        : GPU requires reset
        GPU Base Power
            Current Base Power                         : Unknown Error
            Requested Base Power                       : 0.00 W
            Default Base Power                         : GPU requires reset
        Min Power Limit                                : GPU requires reset
        Max Power Limit                                : GPU requires reset
    GPU Memory Power Readings
        Instantaneous Power Draw                       : N/A
    Module Power Readings
        Current Power Limit                            : GPU requires reset
        Requested Power Limit                          : GPU requires reset
    Power Smoothing                                    : GPU requires reset
    Workload Power Profiles
        Requested Profiles                             : GPU requires reset
        Enforced Profiles                              : GPU requires reset
    EDPp Multiplier                                    : GPU requires reset
    Clocks
        Graphics                                       : N/A
        SM                                             : N/A
        Memory                                         : N/A
        Video                                          : N/A
    Applications Clocks
        Graphics                                       : Requested functionality has been deprecated
        Memory                                         : Requested functionality has been deprecated
    Default Applications Clocks
    Deferred Clocks
    Max Clocks
        Graphics                                       : N/A
        SM                                             : N/A
        Memory                                         : N/A
        Video                                          : N/A
    Max Customer Boost Clocks
        Graphics                                       : GPU requires reset
    Clock Policy
        Auto Boost                                     : N/A
        Auto Boost Default                             : N/A
    Fabric
        State                                          : N/A
        Status                                         : N/A
        CliqueId                                       : N/A
        ClusterUUID                                    : N/A
        Health
            Summary                                    : N/A
            Bandwidth                                  : N/A
            Route Recovery in progress                 : N/A
            Route Unhealthy                            : N/A
            Access Timeout Recovery                    : N/A
            Incorrect Configuration                    : N/A
            Partition Assigned                         : N/A
    Processes                                          : None
    Capabilities
        EGM                                            : N/A
Yes indeed. Actually posted this here (another nvidia forum bug report) and forgot to add it to this one. I did three actions, and I’m unsure which affected it but pretty sure it was the 3rd:
  1. I had opened my case a few weeks earlier and blew a bunch of dust out of it. But I opened it up more recently, and the way the card is oriented the heatsink and fan point down; but the backside of the card had coated in dust, the dust I hadn’t removed last time had settled onto it. This GTX1650 is a 75W card, and they wanted it to look like a serious gaming card so it’s a dual-slot card due to the size of the heatsink, with 2 large fans on it, it probably has like 400W of cooling. So I seriously doubt this affected anything unless the dust is conductive; the temps on this card are a joke (in a good way, like 35C at a desktop, 50C gaming with fans at about 40%… I got it to 78 in GravityMark but fans were still only at 50% speed, and that was BEFORE I blew the dust out of it.)
  2. 7.0.11 kernel. I doubt this is it either.
  3. I had set “vm.compaction_proactiveness=0”. So I removed this (default value is 20). The reasoning there,the compaction can cause latency spikes and so stutter in gaming (at least in theory), I noted in the other bug report that a fair number of complaints were from CachyOS users…well, CachyOS is ‘bleeding edge’ so they’d get the 7.0 kernel earlier; but that compaction setting is EXACTLY the kind of thing they’d also apply. I do suspect (given I had my freezes as I started to increase memory pressure) that I may have plenty of free RAM, but not in as large a contiguous segment as the nvidia driver wanted. Worst case scenario is to grab a bunch of RAM and free up every other 4K… you can have many GBs of free RAM but only 4KB contiguous. Apparently in the real world (outside the stress test program that does this), Java tends to free up little bits like this. User apps, if they request a chunk, kcompactd and if necessary kswapd run to “defragment” memory and fullfill the request (or it fails if it REALLY can’t do it but this is unlikely unless you are truly out of RAM + swap). If KERNEL code requests some contiguous memory that’s unavailable, I don’t think any of that happens, the allocation simply fails. This proactiveness setting has the kernel run kcompactd ‘ahead of time’ to make sure there’s always a supply of contiguous memory. I haven’t seen a single NVRM message like that since I let this go back to the default “20”. If yours is AT 20, it can’t hurt to try turning it up even higher, the max value is 100; perhaps your workload is having the nvidia driver grab big chunks like crazy, trying out a value of 50 can’t hurt? You can set it “on the fly” with sysctl so you don’t even need to reboot to test a higher value.
Good luck!
–Henry
Thanks Henry!
Still ended up locking up at “vm.compaction_proactiveness=50” too… but was worth a shot!
root@pve:~# sysctl vm.compaction_proactiveness
vm.compaction_proactiveness = 50
Linux pve 7.0.14-4-pve #1 SMP PREEMPT_DYNAMIC PMX 7.0.14-4 (2026-07-07T07:27Z) x86_64 GNU/Linux
Sat Jul 11 07:40:03 2026
| NVIDIA-SMI 610.43.02              KMD Version: 610.43.02     CUDA UMD Version: 13.3     |
|   0  NVIDIA GeForce RTX 5080        On  |   00000000:01:00.0 N/A |                  N/A |
|ERR!  ERR!    P8            N/A  /  N/A  |   13578MiB /  16303MiB |     N/A      Default |
|                                         |                        |                 ERR! |
| Processes:        |
|  GPU   GI   CI              PID   Type   Process name                        GPU Memory |
|        ID   ID                                                               Usage      |
|  No running processes found                                                             |
fun times…
