Buggy NPP ?
Hi again!
I had a closer look on NPP the last days and found some weird things I don’t understand. Please see my other post from today regarding the sum function. My new problem is the following:
Using the nppiMinMax_8u_C4R function, I always get only the result from the first channel, not for all four. So the array is filled with 4 times the value of the first channel, i.e. {min(channel1), min(channel1), min(channel1), min(channel1)} and not as expected {min(channel1), min(channel2), min(channel3), min(channel4)}, max-array respectively.
I can’t believe the NPP library is such a buggy thing, so I think I’m doing something wrong. But what?
Thanks for any help.
int pitch = 0;
	NppiSize size; //image data size
	size.height = 256;
	size.width = 256;
	//alloc image on device
	Npp8u* d_image = nppiMalloc_8u_C4(size.width, size.height, &pitch);
	//alloc image on host
	unsigned char* h_img = (unsigned char*)malloc(size.width * size.height * 4);
	//fill host image with random data
	for (int i = 0; i < size.width; i++)
	for (int j = 0; j < size.height; j++)
	for (int c = 0; c < 4; c++)
		h_img[i*4 + j * size.width*4 + c] = rand() % 255;
	//copy host image to device image
	cudaMemcpy2D(d_image, pitch, h_img, size.width * 4, size.width * 4, size.height, cudaMemcpyHostToDevice);
	NppStatus status;
	//Set all pixel values to {2,3,4,A}
	Npp8u data[3] = {2,3,4};
	status = nppiSet_8u_AC4R(data, d_image, pitch, size);
	//buffer size
	int bufferSize = 0;
	status = nppiMinMaxGetBufferSize_8u_C4R(size, &bufferSize);
	//buffer on device
	Npp8u* buffer;
	//Min/Max arrays on device
	Npp8u* d_min, *d_max;
	//alloc them
	cudaMalloc(&d_min, 4);
	cudaMalloc(&d_max, 4);
	cudaMalloc(&buffer, bufferSize);
	//host min/max
	Npp8u h_min[4];
	Npp8u h_max[4];
	//compute min/max
	status = nppiMinMax_8u_C4R(d_image, pitch, size, d_min, d_max, buffer);
	//copy min/max to host
	cudaMemcpy(h_min, d_min, 4, cudaMemcpyDeviceToHost);
	cudaMemcpy(h_max, d_max, 4, cudaMemcpyDeviceToHost);
	//h_min is (2,2,2,2) but should be (2,3,4,rand())
	//h_max is (2,2,2,2) but should be (2,3,4,rand())
	//Copy image back to host
	unsigned char* h_img2 = (unsigned char*)malloc(size.height * size.width * 4);
	cudaMemcpy2D(h_img2, size.width * 4, d_image, pitch, size.width * 4, size.height, cudaMemcpyDeviceToHost);
	//h_img2 is now {2,3,4,rand(),2,3,4,rand(),2,3,4,rand()...} as it should be
This bug will be fixed in our next NPP release. Thank you for pointing this out.
