How to reproduce: start the Mandelbrot demo and hit ‘d’. On first try I got a completely frozen machine, on second I captured a Xid.
nvidia_bug_report.txt (125 KB)
I have a few questions:
0) Does this problem persist if you’re not using the Coolbits option?
- Have you verified that you’re using the most recent motherboard BIOS?
- Does this problem persist if you remove rhgb from your GRUB configuration (and reboot)?
- Does this problem persist if you are using the latest RHEL-5.1 kernel?
- Its not clear whether you’re experiencing instability every time you run this app, or just occasionally?
thanks,
Lonni
Yes. Actually, I just have it set, I’m not “using” it, i.e. no overclocking.
I have 1.6. The latest is 1.7 which has e.g. new ACPI related bugs – I have already tried it, but not in connection with CUDA. Anyway, this board is now for more than 1 1/2 years on the market. They don’t fix bugs anymore. They just add support for newer CPUs – and introduce more bugs.
Yes.
I’ll try it when CentOS 5.1 is out.
Edit: No change with 2.6.18-53.1.4.el5
Every time. It’s completely reproducible.
