TL;DR If you happen to have a CUdeviceptr that actually needs 64bits and stick that in the SBT as the base for any of the entries, your optixLaunch will fail spectacularly (with a CUDA_ERROR_ILLEGAL_ADDRESS).
So to start this off…
Let’s note that on the “Device Side” (actual CUDA code) the value of sizeof(CUdeviceptr) is 4 while alignment is 8, unless I’m using NVRTC wrong somehow (I don’t see an explicit 64bit option).
I added some debug to my program and I saw that my CUdeviceptr inside the SBT on the Host side are using some upper 32bits of the storage.
Here are my CUdeviceptrs for the raygen, miss and hit pointers in the SBT, as you can see the 9th hex digit is 2. 0000000203800000 0000000203A00000 0000000203C00000
And here’s the result of printing the pointer RayGenData* rtData = (RayGenData*)optixGetSbtDataPointer();
GPU 0000000003800020
As you can see the 2 in the front got truncated.
I had a look at the implementation of optixGetSbtDataPointer and it does a unsigned long long to CUdeviceptr cast.
Now I’d guess the examples work because they’re not using OpenGL interop, nor the CUDA Driver API, nor JIT compilation (unlike me where OpenGL is the owner of all buffers and images), and you are unlikely to get a pointer outside the range of 32bits with cudaMalloc or cuMemAlloc.
But cuGraphicsResourceGetMappedPointer does return some pretty high values.
I’ve made a tag with a reproducable example from my engine
as well as a binary build (unfortunately to run it requires your OptiX CUDA headers to be present under “C:/ProgramData/NVIDIA Corporation/OptiX SDK 7.0.0/include”, cause I’m jit-ing the raytrace programs)
It would probably help to report on which versions of Visual Studio and Cmake you have. If you are using VS2019, be aware the cmake setup doesn’t work out of the box. And even with VS2017 and the most recent Cmake, I have to specify a 64-bit toolchain manually.
Since I’m doing NVRTC I just figured I’ll compile for the highest compute virtual arch compatible with the weakest device found on the system. If there is no Turing board I’ll keep on dropping the NVRTC option arch all the way down until sm_30.
I’m always on the 64bit toolchain.
It’s now fixed, I did what jitify (and the post David linked) people told me to do
Now I simply define _WIN64 or __LP64__ for NVRTC when compiling my optix programs.
