bugs in cutil.h macro definitions
There are a number of macros in cutil.h and some of the multiline ones are defined in a way that can produce syntax errors when used in a if … else … block. For instance there is
#  define CUFFT_SAFE_CALL( call) {                                            \
    cufftResult err = call;                                                    \
    if( CUFFT_SUCCESS != err) {                                                \
    fprintf( stderr, "CUFFT error in file '%s' in line %i.\n",         \
    __FILE__, __LINE__);                \
    exit(EXIT_FAILURE);                                                               \
and if it is used as
if( something )
    CUFFT_SAVE_CALL( call );
else
    something else
will give a syntax error. The usual way to define multistatement macros is to wrap it in a do{ … }while(0) block which doesn’t have the above problem.
You’re right, thanks. We’ll fix this in our next release.
