I just installed the OpenCL drivers from http://developer.nvidia.com/object/get-opencl.html and the implementations seems to be full of bugs. I develop an image processing app with Snow Leopard and now I tried to run the same code on Windows 7 64bit/GTX 285 & GT 120. Already this short code sequence fails.
__kernel void process(read_only image2d_t imgSrc, write_only image2d_t imgDst)
int2 coord;
float4 col;
bool pixelValid=true;
const sampler_t samplerSrc=CLK_ADDRESS_CLAMP | CLK_FILTER_LINEAR;
coord.x = get_global_id(0);
coord.y = get_global_id(1);
if (coord.x>coord.y) pixelValid=false;
col=read_imagef(imgSrc, samplerSrc,(float2)(coord.x,coord.y));
// if (coord.x>coord.y) pixelValid=false;
if (!pixelValid) col[0]=1.0;
write_imagef(imgDst,coord,col);
It looks like if pixelValid is always false.
If you use the second if line after the read_imagef it works correct. Also it seems that the compiler doesn’t like more then 3 “if” statements in general. Am I missing something?
